Question about Porter Cable C2002 150 Psi 6 Gal Compressor
Porter cable 135 psi 6 Gal model no. d27420 (homedepot) motor fried ! Can't find replacement, and if i do is it worth fixing? Looks like parts cost as much as compressor
    Sergeant:
    Novelist:
  • 176 Answers
These units are disposable so if the motor is gone, it is garbage. I would try a power tool repair center to see if they have any used motors to repair your unit. Save the tank and use it as a slave unit for a new compressor. This way you will have more volume and the compressor will run less overall making the new unit last longer. If you burnt the motor out on this one, consider buying a larger unit the next time. Hope this helps.
Posted on Mar 21, 2011
  • wayne daubs Mar 21, 2011
    my thoughts exactly, Thank you for the quick reponse..
The regulator knob is broke. Where can I get a replacement? Replacement parts diagrams do not show the knob as replacement part.
You can't buy the regulator knob as a seperate part, you have to buy the entire manifold; Porter Cable part number N003001. Shop around on parts sites as these cost around $70 plus any shipping and handling. Depending on how often you have to change the regulated pressure output it may not be worth replacing.
Jan 20, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I need a new piston ring for a 6 HP Porter Cable air complrssor. It is made of some sort of fiber or perhaps teflon like material. I made a leather one but it just did not last very long. the model...
The part number is DAC-308 and you can order the part from www.msservice.net or you can also try www.allpartsinc.com
You wont need new o-rings for the head just put a little grease on the o-rings and install them again.
Nov 06, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
PORTERCABLE COMPRESSOR
hi there,
there are considering factors to be check.the belt tension of the motor should be fitted between motor and compressor to avoid slip tension of the belt.adjust motor alignment.if still not compressing air
or lost compression replace piston ring.have a nice day dont forget to fix my rate/thank you
May 07, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Trying to wire up my new air compressor, need help with wires.
If you are trying to connect power lines directly to the motor then stop what you are doing, I advise you refer to the owners manual for correct wiring of the compressor. I would highly advise that you seek the service of a professional to hook it up. otherwise you could damage the equipment or worse yourself.
Dec 09, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
489 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
