Question about Baby Doll Peek Boo Baby Doll Set Black S/M
I visited uk last month and bought my baby doll for my 4yrs daughter due to overweight of luggage the box of the doll and instruction manual left behind in uk .now i really dont know how to use it. when i turn her button on it ask for her name i replies for many times but she continously asking name. i think without name she will not able to perform her other function . so plese send me complete instruction on my email.ishall be greatefull to you.
Have a 2004 hd sporster roadster carb rejet kn filter python mufflers bike pings at high rpm around 3500-4500 other than that it runs great what could cause this ty
Hi, Michael to avoid premature engine wear and damage this condition should be eliminated "ASAP" and the usual suspects are:
1. Fuel octane rating too low.
2. Compression too high due to excessive carbon deposit buildup on top of the piston, top of the cylinder bore, and cylinder head dome.
3. Engine overheating due to lack of lubrication, coolant, or lack of cool air passing by top end cooling fins due to accessories or bike not moving.
4. Engine under heavy load due to riding double overweight luggage etc.
5. Fuel-air mixture too lean or too rich.
6. Outside air temperature too hot for the load (dessert).
7. Faulty knock sensor.
8. Electronic ignition timing too far advanced due to faulty sensor inputs (MAP, CKP, CMP)
9. Points plate too far advanced or mechanical advance mechanism worn out.
10. Blocked exhaust causing excessive backpressure.
11. Incorrect spark plugs for the kind of service causing overheated tip.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
https://www.6ya.com/dialer $ 6 a month cheap
Mar 20, 2016 | 2004 Harley Davidson XL 1200 R Sporster...
Zapf Creation Baby Born Doll D-96472
is this a doll that eats and (poops?)..the mouth is an upper hole and the lower hole should be a spot under the main body..if food particles are inside the dolls' body may need a tool like the old water pic flossing macine to clean it out..it is possible to redo a small garden sprayers tip/nozzle to accomodate cleanout of this doll..catch is to find some sort of presurized hose tip to put in the mouth cavity to clean out the body of residue..if that is what is happening..
Jan 15, 2014 | Zapf Baby born 778166
Do I need to buy a luggage scales? My luggage overweight frequently.
It is often you may carry a lot of things in your luggage and thus when you are checking in at the airport, you have to weigh your luggage. If the luggage is overweight then one has to pay some extra money for it. So it is advisable that you would better buy luggage scales and weigh your baggage before going to the airport. This can help people save a lot of money and also help you in carrying the baggage easily.
Jan 05, 2013 | Cars & Trucks
My grandaughters baby born doll won't close his eyes when you put dummy in. you can manually close the eye so it isn't stuck. any ideas how to fix this
We had the same problem a few months ago. We even bought another dummy, but it did not help. Then we found the solution by ourselves. My daughter took her baby born to her bath and we put her into the water. Then I pressed ******* the face for water to go inside through the eyes many times. After I did it a few times with a lot of water the doll start to close and open her eyes again with her dummy. I do not know for what reason but eyes start to stick inside. I believe it may be because of the food, or dust. Maybe not. However from my observations it happen when we did not bathe her for a long time.
I hope it helps.
Aug 04, 2012 | Zapf Baby born 778166
Assembling seat of chicco dj baby walker
Possibly the worst instructions I have ever seen! However, I got it in the end. Reference the manual and follow these instructions. The padded seat folds over the the rigid backrest (c) (don't do this yet!). Start by dropping the front 2 rings through the slots, then, put your finger through the ring underneath the walker and pull (quite hard) until it comes right through and folds over so it can't pull back out. The seam of the padded seat fits into the groove where the ring slots are. repeat this for the next 2 and it should work itself out from there. Hope that helps!
Feb 06, 2009 | Galt America Baby Walker Push-Along Hand...
Baby Doll Peek Boo Baby Doll Set Black S/M Logo
76 people viewed this question
Top Baby Doll Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Baby Doll Toy Expert? Answer questions, earn points and help others
