Question about LG Washing Machines
OE code appears . There ae no kinks in the drain hose. How do I clean the drain filter?
    Sergeant:
  • 192 Answers
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
Oe code, i need to clean the black hose on the bottom of the washer how do i do that. thanks
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | LG WM-2277HW Front Load Washer
Oe error code
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludgeOR "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check wiring harness
· Check water inlet valve
· Check pressure sensor switch
· Check circuit board
Feb 20, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washing Machines Logo
29 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
