Question about Whirlpool Duet GHW9150P Front Load Washer
What does error message F35 mean? - Whirlpool Duet GHW9150P Front Load Washer
    Sergeant:
  • 192 Answers
Http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked.
Posted on Mar 21, 2011
  • 98 Answers
See page 20 of the manual: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182748.pdf
There are some other manuals all related to this type of model here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GHW9150P&siteCd=WHRCOM&userType=Servicer
My Duet has the service manual with more detailed F codes inside the front lower panel. You have to remove the panel to get to it.
You could call a local appliance repair and they will probably tell you as well.
Fault code F35 on my washer what does it mean?
The F35 error code indicates an analog pressure sensor error. ... This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.Jun 3, 2011
SOLVED: F35 error code appears during cycle - Kenmore Elite HE3 ...
https://www.ifixit.com/Answers/View/54204/F35+error+code+appears+during+cycle
See this link and watch the videos
Fault code F35 washer Google Search
Jul 31, 2018 | Washing Machines
What is the solution of error35 in w455h washing machine
Hi! If you mean error F35, this error code indicates an analog pressure sensor error. This sensor is the component that detects water level in the washer tub.
F35 error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor.
Apr 27, 2017 | Washing Machines
Getting an F35 error message on a front loading kenmore washer. Any suggestions?
This link should help:
http://www.managemylife.com/mmh/questions/123674-does-f35-error-code-indicate-kenmore-front-load-washers
May 20, 2011 | Kenmore Front Load Washer
I keep getting the error message F35. Can you tell me what that means?
The Central Control Unit detected a fault in the analog pressure switch but it could also indicate a draining problem. Check the link below to see what you can try to address the problem.
Troubleshooting Error Code F35 on Kenmore Elite and Whirlpool Duet Washers
Nov 03, 2010 | Washing Machines
Suds then F35 error. No soap in the washer. Gets
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Aug 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
2. Check if the airtrap is not blocked.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message F35
F35 indicates a FUSER failure.
Sep 23, 2009 | Ricoh Aficio 1013F Copier
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
