The error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
no i didnt
there should be a two digit blink such as 2 blinks slight pause the another series of blinks. It has to be a two digit code.
Okay a 12 code means no error detected. try unplugging one of the CRT circuit boards one at a time then try powering it up to see if one of your tubes may be shorted. Un plug it before you remove the crt board one tube at a time.
did you receive my last transmission regarding the blinking codes?
I don't see my last comment regarding the blinks..... I've held down the menu and device buttons and blinking that occurs is ....blink off blink off blink off... if I had to count it, it would be 1 blink off 1 blink off 1 blink off and so on.....
let me try it again....
okay... I depress the buttons, the light comes on then goes off, comes on, goes off, comes on, goes off. Kinda lik one - two, one - two, one - two.... but it doesn't flash a bunch of times, just on and off for a total number of times (20). Then the light goes out....
