Question about Eagle Sport & Outdoor - Others
Need transducer for eagle strata 128 fishfinder
SOURCE: Eagle Cuda 250 Fishfinder / GPS combo
Don't buy - go to Eagle web site and download it.
Posted on Jun 03, 2008
SOURCE: Need Instruction manual
I downloaded one from the eagle website.
http://www.eaglenav.com.au/upload/Eagle/Documents/Manuals/CUDA242_0143-842_3-02-06.pdf
Posted on Aug 24, 2010
  • 29 Answers
SOURCE: I have my Humminbird fishfinder
I would contact our customer service group and they will be able to help you. Our number is 800-633-1468.
Posted on Jan 11, 2011
  • 2386 Answers
SOURCE: need user manual eagle 500c gps fishfinder
Hello
Here is the link to download
http://www.eaglenav.com/Products/Fishfinder-Chartplotters/FishElite-500C/Downloads/
hope this helps
Posted on Jan 27, 2011
dcramer531
  • 1654 Answers
SOURCE: I have an old Marinetek
Unfortunatly that transducer will not work on the new unit. The sonar sensor is not compatible with this transducer and I would doubt it would even match up to the plug in the Garmin. These units are very propriatory and you will have to use the transducer that came with the machine or one that was specifically designed for the sonar unit. The transducer for your newer unit should be able to mount flush on the hull without having to pull your boat out of the water. These newer units have the capability to see through the hull without having to mount them externally.
Posted on Jul 29, 2011
How do i seal the transducer so it works through the hull
You want to use a special BELOW THE WATERLINE sealer, you get from a marine supplier. This material takes DAYS to cure, so crank that in to your plans.
Jul 07, 2011 | Eagle Cuda 242 Fishfinder
I've purchased an Eagle 320 fishfinder 2 years ago and I've had to replace my transducer twice. Every time I'm out fishing lakers in 50 to 100 feet of water, I keep loosing the bottom mark and...
I have never heard of Eagle Fishfinders, but I would be inclined to package it up and send it back to them for checking under warranty, with a fault that should never happen. The brand leaders are Lowrance and Humminbird, with Garmin in 3rd place.
I have a Humminbird 998HD with Side Imaging. I had a 798SI before that and never a problem. the 998 cost me nearly 2 grand Canadian and is used on Lake Ontario, twice a week every week from May to October, and has been faultless. The 798 was used from 2008 to 2014 and also faultless. I think you have a 'Friday Special'.
Mar 14, 2017 | Eagle Fishmark 320 Portable Fishfinder
Have a Cuda 300 It shows 62 ft on water or land. This is my second new unit, the first one did the same thing. Tried factory reset.
The transducer for the unit might have junked out, or else you have a floor model that is programed for that depth. lol
Apr 14, 2010 | Eagle Cuda 242 Fishfinder
Water temp is not working can that be fixed?
Double check you have a good connection from the transducer data cable to the back of the display unit and that the pins are not corroded or anything similar. If the temp has never worked at all, it may be because the transducer you are using doesnt have a temperature sensor onboard and you will need to get one that does have this feature. If it did work previously and you checked the pins/connection (as per above) then the transducer is faulty or has developed a fault. There is no real easy fix and it will most likely be far cheaper just to buy a new transducer than to have the current one repaired by Eagle. I think new trasnducers are about $60-$70.
Mar 30, 2010 | Eagle Fishmark 320 Portable Fishfinder
Eagle Fisheasy No screen display and only beeps
You could have blown the transducer.....it is supposed to be in water before you turn it on. A 5 gal. bucket inside the boat would be fine for when out the water. Put the transducer in the 5gal bucket with water and try again. You may have to get another. sorry.
Dec 20, 2009 | Eagle Fisheasy 250ds Fishfinder
Sonar does not appear to work - not picking up depths or bottom structure. All other functions look good.
This problem is most likely linked with your transducer.
1. Check your transducer cable and make sure the plug terminals are clean, as well as the plug on the back of the unit.
2. Make sure the transducer cable is plugged in correctly and securely.
3. Make sure the transducer is in the water and mounted according to the directions, parallel to the bottom of the boat
4. Turn the unit on while the boat is in the water, but with the engine OFF.
IF it works when the engine is off, but vanishes when the engine is on, you may be having electrical interference.
IF it works when the engine is running, but vanishes when the boat is moving, it is a turbulence problem. Move the transducer.
IF it does not work at all, try borrowing a new or a "known good" transducer and seeing if it works then. If so, replace the transducer.
Let us know if these work or now.
Oct 15, 2009 | Eagle Fishmark 320 Portable Fishfinder
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Sport & Outdoor - Others Logo
154 people viewed this question
Top Eagle Sport & Outdoor - Others Experts
Bill Eager
Are you an Eagle Sport and Outdoor - Other Expert? Answer questions, earn points and help others
