Question about Water Heaters
Hi my maxol morocco boiler when i put it on in about 2 mins its like there is air in the pipes i have put a new water pump in today but it is still doing it
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
  • 70 Answers
SOURCE: Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Posted on Jan 23, 2009
  • 2418 Answers
SOURCE: hi i a maxol MALAGA WATER HEATER gas only in my
If the water heater is leaking you have a rusted tank and it needs to be replaced. Turn off the water till it can be replaced. No fix for a rusted tank has to be replaced.
Posted on Jul 29, 2009
  • 150 Answers
SOURCE: central heating circulating pump
The vent pipe should be in front of the pump so that the pump pushes towards the vent pipe NOT sucks from it. I hope this vent pipe is part of the heating system and not of the hot water
Pumps like to push not pull and therefore it is better if the pump is located further down - say at the bottom of the cylinder or lower.
With an indirect cylinder, the hot water & heating are separate circuits and are not and must not be interconnected. You will need a separate pump for the hot water which should be taken from the hot pipe coming out of the cylinder. You may get vacuation in the cylinder - then you will need an Essex or similar valve to replace the hot water outlet connection
By the way - The pressure at any hot tap is directly related to the height difference between the tap and the header tank in the loft [thus a shower downstairs feels stronger than one upstairs]
rod_davies@hotmail.com
Posted on Sep 03, 2009
SOURCE: Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
Posted on Mar 11, 2010
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
NO!!! DO YOU HAVE A MONOFLOW ONE PIPE WITH 2 TEES, OR A SINGLE PIPE LOOP GOING IN AND OUT, OR 2 PIPE SUPPLY AND RETUUN SYSTEM ? ZONE VALVES OR SEPERATE CIRCULATORS ? EATHER WAY BOILER WATER NEEDS TO CIRCULATE FROM SUPPLY TO RETURN. JUST FINISH WHAT YOU STARTED.
Nov 08, 2014 | Water Heaters
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have an older model Ideal Mexico 2 floor standing open flue boiler running a fully pumped system. The central heating isn't working properly despite being flushed etc. The initial problem is still there...
You could undone the return at the boiler to release any air ? if you think there is a air lock . Or turn the pump up to max with the heating on and try to push the air out .
Jun 08, 2017 | Water Heaters
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Non i;n working boiler
Did you put automatic vent plugs on this boiler?This help stop from having air locks.I would try bleeding the high pipe to see if any air come out.The other thing I would check is the valve that out for the pump to pump water around.
Mar 17, 2009 | Water Heaters
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Locating pump on Baxi Back Boiler
hi this problem sounds like a pump problem. now if its not in the airing cupboard, sometimes they can be besides the boiler in a cupboard or under the floor where the boiler is sited, or boxed in in a dummy casing either side of the boiler/fire unit.
i suspectthatthe pump is stuck & needs releasing or worse case scenario a new unit fitted.
The reason you mentioned about frequently getting air in the system is condusive of sludge build up or the pipe-work configuration is not installed correctly giving rise to air being drawn into the system & posing future probs such as component failure.
If the pump is sited under the floor by the boiler it is at risk of collecting sludge as its at the lowest point in the system.
Recommendations re-site the pump if possible & look to have the system power flushed, to assist the life expectancy of the system
Kindly
Richie
Dec 02, 2008 | Water Heaters
Boiler overheating
good luck!!! tim
Oct 08, 2008 | Water Heaters
Water Heaters Logo
83 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
