SOURCE: Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
SOURCE: Okidata - label printing alignment
You might try setting up Word for a 'custom' label since it offers that option.
I've done some strange labels by directing Word via that feature.
SOURCE: printer is not recognizing the new custom paper size
You also have to create a form the same size in "server properties".
Click on "printers and faxes"
Click on "file" top left of screen, choose "server properties"
Click on "create new form"
type in width and height of paper
(my HP printer will not recognize any paper less than 5' in height and less than 3" in width)
If your create a form less than 5" in height ' and/or less than 3" in width - chances are that's why your printer won't recognize new form. Height HAS to be at least 5" and width HAS to be at least 3"
type in name of new form
save form and close
It should now be in your printer paper options.
If your using Windows system you need to go the control and then select printers icon in the control panel and right click on and select printing preferences and change the paper type or use the control on the printer to change the paper type...
Good luck...
SOURCE: c6180 will not print labels as set out in the
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
