I have a Harley Davidson ceiling fan # 81001 that is missing a receiver. Can you please provide a receiver a.s.a.p. Thank you, George Deroche
SOURCE: Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Posted on May 27, 2008
jimmy nutron
  • 132 Answers
SOURCE: what type of motor oil used in 1994 harley davidson 883
harley recomends that you use their oil but i would be carefull because it is a cynthetic now if you were using regular oil what that will do is clean all the old build up out of the motor this can be bad because after time there are pin hole leaks that occure but the build up stops it from leaking but if you use cynthetic you cant go back to regular oil it will gum up on you and ruen your motor so you got to find out what has been put in it. but use a 10-30
Posted on Jun 05, 2009
tundrajet
  • 80 Answers
SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
Posted on Jun 06, 2009
  • 69 Answers
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
Posted on Jun 28, 2009
wd4ity
  • 4565 Answers
SOURCE: Adjusting timing on Harley Davidson 1976 sportster
The advance timing should be 35° before Top Dead Center. This is how you find out which mark this is.
Get the rear wheel of the bike off the ground, remove the spark plugs, shift the bike into fourth gear, and remove the timing plug from the left engine case.
Now, take an ordinary PLASTIC DRINKING STRAW and insert it into the front spark plug hole. Do not use anything else or you stand a chance of it breaking and then you'll have to pull the head to get it out. The plastic straw will bend but not break.
Bump the rear wheel in the direction that it turns while riding down the road until the piston pushes the straw all the way up and just barely starts going back down. Look into the timing hole. You should see a timing mark. This is the Top Dead Center mark. Now, bump the rear wheel BACKWARDS until you see another mark. This should be the ADVANCED TIMING MARK. The piston should 7/16" down from top dead center.
On this model Sportster the timing is advanced by a mechanical advance mechanism. These units are notorious for wearing out and not contolling the timing very well. You must remove the breaker plate to inspect this mechanism. Mark the position of the plate before you remove it. If the pins and holes in the flyweights are worn, replace the unit. Replace it with a good needle bearing unit. Replace the points and reset the gap at 0.018 - 0.020".
Posted on Sep 24, 2009
2006 Dyna Wide Glide sputters & pops
Hi, George sounds like a faulty throttle position sensor for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $8 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Bike Sputters backfires dies help 07 SB Harley Davidson Forums
Harley Davidson DYNA Models Workshop Service Repair Manual 2006 $8 cheap
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak with me personally absolutely "FREE"
Mar 26, 2017 | 2006 Harley Davidson FXDWGI Dyna Wide...
Looking for the fuse box on my 1997 Harley Davidson Heritage Springer . Everyone keeps saying it's under the seat but I have attached a picture and clearly it is not there ?
Hi, George I can see the fuses/circuit breakers on the back side of the cover you are holding in your left hand if this is not what you were looking for contact me at the email address below, for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
https://www.manualslib.com/manual/1001223/Harley-Davidson-1998-Softail.html#product-1997 Softail
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
Instant Tech Relief A must have !!! Absolutely "FREE"
Oct 16, 2016 | Harley Davidson Motorcycles
Fork oil capacity. 2007 Harley Davidson night rod special
Hi, George for this scenario you will need a service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Cycles Capacities and Fluid Requirements Fork Filling Quantities
Fork Oil capacity
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jun 18, 2016 | Harley Davidson Motorcycles
Ceiling Fan Lights won't stay on
Try changing the frequency on the receiver & transmitter.
Nov 24, 2013 | Dryers
Engine is missing how to fix
Hi Andrew, please be aware that this question has already been asked and answered. Thank you.
Jul 06, 2012 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
2000 Harley Sportster 1200S has no spark
Hi Mike, please be aware that this question has already been asked and answered. Thank you.
Apr 15, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
Receiver installation issue
Most of these fans locate the receiver on the mounting plate (metal part fixed to electrical box where ball hangs). The canopy (decorative part that covers the wiring on ceiling's electrical box) has enough space to hide it. I presume you're missing the manual, so install the fan and slip the receiver in the plate, right between the electrical box and the ball, everything's color coded, securely wire cables from ceiling to power cables in receiver and cables from the receiver to the fan. Slide canopy up and securely fasten with provided screws. Good luck!
Nov 01, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
1 qt oil every 1000 miles
kev, check you have the right level on your dip stick, oil must be on upper mark when donk cold.also ensure you are running the correct oil weight for your donk.
engine may be running hot; which means one way oil can go missing is its being burnt.
also check your primary drive,clutch oil level ,not sure as i have 80cube evo, but you may find your oil in there due to bad oil seal internally. im no expert but these may be of help.
regards george
May 14, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Open Questions:
103 people viewed this question
 Grubhead
Grubhead
