Question about Kenmore Coffee Makers & Espresso Machines
I have a kenmore model 100.94006 grinder coffee maker-won't grind coffee-grinder runs, won't feed beans
SOURCE: Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Posted on Jul 17, 2007
espressodoc
  • 29 Answers
SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Posted on Jul 27, 2007
mirran
  • 515 Answers
SOURCE: grinder does not work!
Make sure you not get any damp into the grinder.
Posted on Aug 20, 2008
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Posted on Dec 28, 2008
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Coffee beans are not going into grinder.
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
Jun 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
Beans are too oily
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Aug 06, 2009 | Bosch Benvenuto B30 Espresso/Coffee Maker
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
134 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Jude24
ray gallant
 steve
steve
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
