Question about Hughes SDHBH DirecTV DTV Receiver
Satellite dishes wen down during storm. Attempting to find signal. SDHBH box is unresponsive. Is there a hard reset procedure?
  • 8,457 Answers
Yes,unplug,replug the box back like about an hour later.The box,will reboot and updated it software.The incomming broadcasting signal should be back.If not storm,did more damages to the LB reciever connected on the dish itself.Must call Dish Network to check it out,might have to replace it.
Posted on Mar 21, 2011
OVHD when there is rain OVHD does not work
Your television signal becomes weak in the rain because it is satellite based. Even if you don't have a satellite dish, the company that supplies you does. You need to contact them direct. Or, if you do have a satellite dish, you need to upgrade to either a larger one, or if you are on analogue, you need to upgrade to digital.
Apr 28, 2018 | Cars & Trucks
Good day just want to ask everytime when it rains getting NO SATELITE SIGNAL
Sadly that is going to be a fact of life as any storms between you and the satellite will wash the signal out
Nov 25, 2017 | Televison & Video
I do not have a satellite sisgnal
check power and tv in correct mode -then check alignment of dish --if good and no large storms in area notify sky of problem it may be box or programming
Aug 16, 2016 | Televison & Video
Sky hd box no satellite signal
Have you checked that the dish is still properly aligned? Could the recent storms in the UK have thrown it off? Likewise, have you checked that all the cables and plugs between dish and receiver are in good order? Lastly, if you have a Sky contract, have you called their customer support line?
Nov 05, 2013 | Televison & Video
Star choice
The summer solstice is near and it is common for signals to be misaligned. It does not matter if you are connected with cable or satellite signals. Many techs over look this common phenomena. Any storms (electrical especially) in the atmosphere may contribute to this. You cannot control this. Other things to consider, if you have dish, would be tree branches (beginning to gather leaves and blocking a signal) your dish may have moved and needs realigned (wind or snow caused). Also be sure you have good tight grounds (RF Connections outside as well as in). Be sure you have a good grounding, ground (Earth Ground in this case) if you have satellite reception. Clean the satellite dish, a very good idea. Also, check with your provider, you may need an upgrade with a newer reception box. Hope this will help. These are basic correction tips and not just mumbo jumbo. Thanks for asking me!
May 24, 2013 | Televison & Video
Can urc operate dish tv top box
There is no code for satellite box with this remote control.
Jul 16, 2012 | Televison & Video
How to turn off subtitles on a hitachi tv
This may depend on the signal source of the TV. If you are watching OTA TV (or your TV is interpreting the CC from the cable or satellite signal), then use the CC button on the remote. Alternatively, depending on your exact model Hitachi TV, try using the menu to find a Tools or Options sub-menu and then turn off the CC from there. This could be under a different menu item. If you add a comment with your model number, I'll be glad to give the exact menu steps.
If you have a set-top box (cable, satellite, digital-to-analog converter box, DVD recorder), the captions may be turned on at this source. Then you will need to disable the captions from that box. With a converter box, press the CC button on the converter's remote or enter the menus for that box.
With a Dish TV set-top box, press Menu on the Dish remote, go to Properties (item 9). Click Select and then go down to Closed Caption (item 6), and press Select again. The first item in this sub-menu lets you turn on and off the captions. Press the left button and then up or down arrow followed by Select to change the setting. For other sources, check the instructions for that device or add a comment with the specific source for a solution for that device.
I hope this helps.
(the Dish CC procedure is for the box I have to deal with; I can't guarantee that updates/model changes have not changed the procedure.)
Jul 15, 2012 | Televison & Video
I have lost my digital satellite reception. All I getting is No Signal or Bad channel.
could be a couple things. First I would check the cable(s) from the dish to the box. Check whether the connections are corroded, but also check the insulation. squirrels, rats mice and birds love to eat the stuff. You have a signal leak somewhere. If everything looks good there, you might check the positioning of the dish itself. maybe it moved during a storm.
Aug 29, 2009 | Coship CDVB2000E
Lost signal from the satellite
Signal Fade And Loss ~ Important, especially during winter!
Keep in mind that satellite broadcasts occur directly from fixed satellites in space to users. UPLINKS TO that satellite can happen from almost anywhere in the world! This includes broadcasts from remote studios, satellite vans and trucks.
Even signals from the main providing studios are susceptible to weather conditons even tho they have huge, high-gain transmitting dishes!
Weather is a major factor for both the uplinks and downlinks! Storm clouds can block the signals anywhere in the signal path(s). Rain clouds do too ~ even if it's not raining yet. Water-laden clouds make some of the BEST signal attenuators.
So one may have a gorgeous day in San Diego (let's say), but storms back east could trash satellite reception at his location and potentially everywhere else!
As you know, weather conditions all over the US are changing constantly with many severe storms occurring this past week and during any winter. In fact this week there was total signal loss on several satellites and I suspect storms back east were a big factor.
So it could have just been issues of timing for you. The UPLINK had intermittent problems with signal paths semi-crippled by weather... YOUR weather was CLEAR, but your reception was far from problem free ~ only because of weather problems elsewhere.
If you see intermittent satellite reception do check out the weather... especially back east.
Hope this helps!
Feb 01, 2009 | DISH Network Televison & Video
No satellite
probably fried the lnb on the dish or the receiver itself
May 07, 2008 | TruTech PVS2119 19 in. LCD Television
Hughes SDHBH DirecTV DTV Receiver Logo
156 people viewed this question
Top Hughes Televison & Video Experts
jason
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
