Question about GPS
Soft top it does not open electric arial the cannot lock doors only with keys button on the luggage
    President:
  • 2,047 Answers
Sorry but your question lacks critical information. What model and make are you referring to please give more details about the products and also the event which led to the malfunction.
Hoping to hear back from you.
Posted on Mar 21, 2011
2003 town car trunk wont open with remote or button on door, only key?
Luggage Compartment Lid
The luggage compartment lid module receives a voltage signal from the driver door module (DDM) when either the button on the driver door trim panel, the keyless entry keypad, or the transmitter is pressed (twice on the transmitter). Voltage is then supplied to the luggage compartment lid latch, opening it. Using the luggage compartment lid key operates the latch mechanically, resulting in manual-only operation of the lid. There are two switches in the latch. One is monitored by the luggage compartment lid module to sense if the latch is closed. The other switch in the latch is monitored by both modules (LCM and luggage compartment lid module) and is used for disabling the anti-theft system, which is contained within the LCM. The luggage compartment lid module powers the lid motor to move the lid to the full-open position when it senses the latch has been opened. Optical sensors within the lid motor are monitored by the module to determine when to turn off power and which circuits should be powered or grounded to the lid motor. When one of the buttons is depressed with the lid open, the DDM sends a signal to the luggage compartment lid module which powers and grounds the correct circuits to the lid motor and lowers the lid until the latch closes. The module senses the latch closing through the lid latch switch that is monitored. At this time, the module powers the closing motor, slowly pulling the lid to a fully closed position. Two switches within the closing motor are monitored by the module to determine when the closing motor is fully down or up. The module has a vehicle speed output (VSO) (circuit 679) signal that is used to shut down the system if there is a VSO of approximately 5 kph (3 mph) or more. For diagnostics, the module uses the ISO-9141 circuit 70 that is included in the DLC (data link connector). Whenever battery power is lost to the luggage compartment lid module, luggage compartment lid motor or the luggage compartment lid closing motor; the system must be initialized.
NOTE: The luggage compartment lid motor is equipped with an optical sensor that the module uses to determine if the lid is closing on foreign materials based on lid speed. If the module detects this occurring, power and ground will be reversed to the lid motor and the lid will open.
  1. Verify the customer concern by operating the luggage compartment lid using the four different methods (driver door trim panel button, transmitter button, keyless entry keypad and key) to duplicate the concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Luggage compartment lid motor
  • Luggage compartment lid closing motor
  • Luggage compartment lid latch
  • Luggage compartment lid and hinges
  • Battery junction box (BJB) fuse(s):
    • 109 (40A)
    • 1 (30A)
  • Central junction box (CJB) fuse(s):
    • 30 (7.5A)
    • 14 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step. Verify the two grounds (G204, G401) are clean, tight and free from corrosion. Remove and clean to make sure.
  1. Monitoring the PIDS in the luggage compartment lid module can verify the DDM is sending the lid-open signal to the lid module. They can also be used to determine if the latch switches, the lid switches and the lid motor sensors are all providing the luggage compartment lid module with the correct and necessary information to operate the system. The VSO input can shut the system down if there is a signal indicating 5 kph (3 mph) or more.
  1. If the electrical lid operation is ok, but the key is ineffective, refer to Section 501-14 .
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) located under the instrument panel and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
    • If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the DATA LINK DIAGNOSTIC TEST. If the diagnostic tool responds with:
    • CKT 914, CKT 915 or CKT 70 = ALL ECUs NO RESP/NOT EQUIP, refer to Section 418-00 .
    • NO RESP/NOT EQUIP for luggage compartment lid module, Go To Pinpoint Test A .
    • SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the luggage compartment lid module.
  1. If the DTCs retrieved are related to the concern, go to the luggage compartment lid module Diagnostic Trouble Code (DTC) Index to continue diagnostics. For lighting control module (LCM) concerns, refer to Section 419-10 for a complete DTC index.
  1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart. Luggage Compartment Lid Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Luggage compartment lid module INSTALL a new luggage compartment lid module. B1359 Input Low When Key in RUN/START Position Luggage compartment lid module Go To Pinpoint Test A . B1551 Latch/Lid Release Circuit Failure Luggage compartment lid module Go To Pinpoint Test C . B2418 Sensor Power Short to Ground Luggage compartment lid module Go To Pinpoint Test B . B2419 Sensor 1 Invalid Luggage compartment lid module Go To Pinpoint Test B . B2420 Sensor 2 Invalid Luggage compartment lid module Go To Pinpoint Test B . B2421 Vehicle Speed Sensor Circuit Failure Luggage compartment lid module Go To Pinpoint Test C . B2522 Vbatt 1 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A . B2552 Vbatt 2 Open Luggage compartment lid module Go To Pinpoint Test A . B2698 Vbatt 2 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A . B2703 OPEN CLOSE SW Input Stuck Active Luggage compartment lid module Go To Pinpoint Test B . B2718 Lid Ajar Output - Short to Battery Luggage compartment lid module Go To Pinpoint Test B . B2721 Lid Ajar Output Circuit Failure Luggage compartment lid module Go To Pinpoint Test B . B2748 Drive Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test B . B2755 Drive Motor Short to Battery Luggage compartment lid module Go To Pinpoint Test B . B2757 Drive Motor Output Short to Ground Luggage compartment lid module Go To Pinpoint Test B . B2825 Obstacle Detection Path of Decklid Luggage compartment lid module Go To Pinpoint Test B . B2876 Striker Drive Short to Battery Luggage compartment lid module Go To Pinpoint Test D . B2877 Striker Drive Output Short to Ground Luggage compartment lid module Go To Pinpoint Test D . B2905 Striker Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test D . B2906 Striker Up SW Input Invalid Luggage compartment lid module Go To Pinpoint Test D . B2907 Striker Down SW Invalid Luggage compartment lid module Go To Pinpoint Test D . B2908 Latch SW Input Invalid Luggage compartment lid module Go To Pinpoint Test B . B2910 Striker Up SW/Striker Down SW Mismatch Luggage compartment lid module Go To Pinpoint Test D . B5131 Clutch Circuit Failure Luggage compartment lid module Go To Pinpoint Test B . C1123 Vehicle Speed Sensor Circuit - Fault Luggage compartment lid module Go To Pinpoint Test C . Do you know what diagnostic trouble code's are ? That would be the first place to start , checking for code's . An seeing how you probably don't have a ford IDS - scanner . your best bet mite be to take it to a qualified ford - lincoln dealer
Jun 07, 2018 | Cars & Trucks
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
https://www.youtube.com/watch?v=TI4AgFhcnys
Sep 16, 2017 - Uploaded by Distant Lands Travel Store
http://www.distantlands.com How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA Lock® & Cable - YouTube
? 1:21
https://www.youtube.com/watch?v=QlysHXuaftY
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ...
traveltips.usatoday.com > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Feedback
Lock Instructions - Samsonite
https://www.samsonite.ca/lock-instructions.html Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
2003 grand marquis ls door locks and trunk not working
Hi, sounds like you may have lost power. Check your fuses, remember, you have fuses in the cab and under the hood. Hope that helps
Oct 10, 2017 | Cars & Trucks
Battery dead. how can I get trunk open.
You can't unless it has a key hole. If you put jump leads on the battery or connect a battery charger it will open straight away.
May 01, 2016 | 2008 Ford Taurus SEL
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
Where is the alarm system on 2005 lincoln ls?
Anti-Theft - Perimeter The anti-theft perimeter protection feature is controlled by the front electronic module (FEM), the rear electronic module (REM), and the driver door module (DDM). The alarm can be armed using:
  • the LOCK button in the remote keyless entry (RKE) transmitter to the DDM, which sends a message through the standard corporate protocol (SCP) communications network to the FEM.
  • the driver or passenger door lock switch if the corresponding door is open when LOCK is actuated.
  • the key in the driver door lock cylinder.
  • the RKE keypad by pressing 7/8 and 9/0 simultaneously.
The FEM and REM then monitor all features, which activate the alarm in the event of an unauthorized entry.
The luggage compartment lid lock cylinder does not disarm the vehicle's perimeter alarm. The luggage compartment alarm can be temporarily inhibited through the luggage compartment lid disarm switch, located in the luggage compartment lock cylinder or by opening the lugguage compartment with the RKE transmitter or the RKE keypad. Once the luggage compartment lid closes, the perimeter alarm system immediately starts monitoring the luggage compartment. The perimeter alarm can only be disarmed:
  • by unlocking the vehicle using the RKE transmitter.
  • by unlocking the vehicle using the driver door lock cylinder switch.
  • by cycling to RUN a valid programmed key in the ignition switch.
  • by entering the correct vehicle unlock code on the RKE keypad.
Additionally, an ignition switch tamper circuit and a signal hardwire line from the FEM to the REM are monitored.
If any of the above features receive any activation once the alarm is armed, the alarm activates the visual and audible alerts. ......
Jan 06, 2015 | 2005 Lincoln LS
Lost my keyes to my luggage can a locksmith help key no. is 713
Yes or a luggage shop there aren't that many type of keys. But call first it might save you a lot of running around.
Sep 17, 2012 | Ultra Hardware Black Dog 55164 3 Digit...
How do I change the license plate light?
License Plate Lamp Removal & Installation To Remove:
  1. Remove the luggage compartment lock cylinder.
  2. Remove the luggage compartment door garnish molding.
  3. Release the retainers and remove the license plate lamp assembly.
  4. Disconnect the harness electrical connector.
To Install:
  1. Connect the harness electrical connector.
  2. Engage the retainers and install the license plate lamp assembly.
  3. Install the luggage compartment door garnish molding.
  4. Install the luggage compartment lock cylinder.
Jan 14, 2011 | 2003 Toyota Corolla
How tor resync convertible top button switch flashes
The soft top control module should reset every time the ignition switch is off and the key is pulled out. There are two types of flashes. If the switch flashes fast it means the luggage cover in the trunk is not in place. If the light flashes slow it means there is an electrical problem. Meaning the control module is not seeing one of the micro-switches in the correct position. You can try manually opening and closing the soft top by locating the pressure relief screw in the back of the trunk. There will be a little flap of carpet towards the left center. Use a flat blade screwdriver to turn the bleeder screw to the left. This allows the hydraulic fluid to bypass the pump so that the top can be moved manually. You will need a 5mm allen to unlock/lock the latches.. Double check in the owners manual there might be illustrations I can't remember for sure if it does or doesn't.
Oct 01, 2010 | 2001 Mercedes-Benz CLK-Class
My soft top is not working, wont go down, when I release the catch the windows go down and when i press the up button to close thr roof the windows close but roof doesnt
No doubt your soft top issue has long been resolved but just in case someone has a similar issue:
I started to open my A4 Soft top externally using the door key method and like an idiot I must have disengaged the key before the soft top was fully down. I was unable to activate the opening or closing of the soft top automatically using either the key or soft top switch inside. I then manually closed the soft top using the users handbook and manual tool supplied. Soft top would still Not open automatically and the soft top alarm would activate. I solved the issue by manually opening the soft top fully and then manually closing the soft top fully. This seemed to have reset whatever had gone askew.
Oct 20, 2009 | 2003 Audi A4 Cabriolet
GPS Logo
22 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
