Question about Maytag MHWZ400T Front Load Washer
My washer is very load now? and around the gray rubber seal I found big gashes and scraps in the white plastic. not sure what it is only had them since Oct.
    President:
  • 2,468 Answers
QUIT using this machine,I just had one similar to it and the inner tub was off center,I removed the whole inner basket and center shaft to the rear from the belt drive pulley and found that the aluminum spider that holds the inner tub had shattered due to moisture and detergent ROT, get the unit apart and check for this problem,because when it spins out it can or could fly apart inside the outer tub,this was a General Electric front load washer unit,but all the issues you have are identical to this one,by the way,the customer filed a claim with G.E. and after fighting with them got a brand new washer with a FULL warranty at no charge............check it carefully and then go after the company
Posted on Mar 21, 2011
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
The plastic boot has a rip in it. How difficult is
If you are referring to the door bellow (gray rubber seal), the following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be found at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites also have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
Read through the link provided and if you have questions, please post back and let me know. I hope this helps you.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Hole in rubber seal on Whirlpool Duet washer
I'd replace the seal. It isn't expensive and it isn't hard to do. You can avoid a lot 'o scrubbing by running an empty load on whitest whites with bleach occasionally and occasionally cleaning out the strainer inlet to the pump, where things tent to collect and fester.
--Regards, --WoobieDog--
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Grey scum marking clothes
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
And rate me plz……………………….
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Oct 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Maytag MHWZ400T Front Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
