Question about Ruud Heating & Cooling
Ruud unit the fan will not turn on for the "cool" setting, but will turn on for the "heat" setting, any ideas of potential issues?
    Genius:
  • Ruud Master
  • 1,033 Answers
Hello, does the outside condensing unit start when the thermostat is set to cool? if so, the relay on the integrated control board is bad and the board must be replaced. If the outside unit does not start then most likely the thermostat is bad.
Posted on Mar 21, 2011
Ruud classic 90 furnace (LP) doesn't come on. Fan will run when thermostat set to on (heat & cool both off. Troubleshooting chart?
will you need to put either heat mode on or cool mode to on for any type of operation other than just fan on
Jan 14, 2017 | Ruud Heating & Cooling
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
Ruud AC fan won't shut off
In many mobile homes this scenario is very common, less so in permanent homes, but here is how it works; The heat side of your fan which is the low fan speed is not dependant on the thermostat it's heat activated. Your already aware of this to some degree because you had the limit \fan switch replaced. I've taken that approach to that unit myself. In reality what probably is happening is on hot days your unit is warming up by being hit by sunshine and then it clicks the fan on at 140 degrees. This especially happens if the unit is on the roof or a split system in the attic. Remedies; run your A\C to cool it down, keep your attic cooler by way of an attic exhaust fan(which saves you cash anyway). Or if your not regularly using A\C turn breaker off til you need it. In the end there may be something going on, but odds are I'm dead on. Good Luck
Jul 12, 2009 | Ruud UBHC Air Conditioner
Ho to turn on central AC unit? (Ruud High Efficiency)
This is typical wiring for a 4 wire thermostat
R = Red One Side of 24 volt Transformer
G = Green Blower relay
Y = Yellow Cool Condensing unit
W = White Heat Furnace
Apr 28, 2009 | Ruud Heating & Cooling
I tried to replace my digital manual Honeywell thermostat that is only 6 months old (new construction) with a programable thermostat. I followed the instructions marking the wires and connecting them up...
Your "R" terminal is basically your "hot" and your "C" terminal is basically your "neutral" to simplify explanation. The Furnace supplies the "R" power to the thermostat and then depending on what wire the thermostat sends the power back on determines what the system does. The thermostat terminals are as follows "G" is fan, "W" or "aux" is elect heat, "Y" tells the outdoor unit to run, "O" or "B" tells the outdoor unit whether it is heating or cooling, and "E" is emergency heat. "G" should connect from the t-stat directly to the furnace and go no further. "W" or "aux" AND "E" should both connect to your "W" or "W1" terminal in the furnace, there should also be a "W" connection to the heat pump ( this allows the H/P to turn on the elect heat when the unit defrosts) "Y" and "O" or "B" may or may not connect to a terminal in the furnace, usually they just pass through the furnace from the t-stat to the H/P and get wire nutted in the furnace. Now, here is the key. As I mentioned previously "O" or "B", a system will only use one or the other. The entire industry (except for Rheem and Ruud) uses the "O" terminial which has 24v on it when you are cooling and no power when you are heating. Rheem and Ruud use the "B" terminal which is just backwards, 24v in heating and no power in cooling. This is all for a heat pump, If you do not have a heat pump, then disregard the references to "O", "B", "E", and "aux". You will have R-power on red wire, W-heat signal to furnace, G-fan signal to furnace, and "Y" cool signal to outdoor unit.
Jun 08, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
