Question about Amana ARS2464B Side by Side Refrigerator
Amana ars2464bs quit working overnight. Freezer may have been left ajar, all night. The motor is hot and a clicking sound can be heard every couple of minutes. Frige and freezer room temp.
  • Amana Master
  • 4,655 Answers
Unplug and manual defrost This happens when warm moist air is drawn into refrigerator. It freezes as frost and confuses the motherboard or defrost timer and put a heavy strain on compressor.. You also have a defrost timer inside the fresh food compartment. It is possible you can run forward to force defrost=> 67001036 Defrost Timer turn timer with small flathead screwdriver slowly clockwise.Click Here=> ARS2464B Amana Refrigerator Control Parts List Part 711 in top left photo can be found in the control panel inside the fresh food compartment. Try that and let me know if this helped, Thanks, Sea Breeze
Click Logo below=>
Posted on Mar 21, 2011
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Condenser freezes up and the fridge gets warm, I thaw out the condenser and its works great for a couple of weeks. the unit is a amana bottom freezer ARB1917C. thank you
It's the evaporator that's freezing up from failure of an item in the defrost system. You'll find you have a bad timer, heater or thermostat. The timer is located in the control panel, centered towards the rear. Turn it cockwise with a flat blade screwdriver. A tick will be heard for each advance of the timer. Continue until a loder click is heard and the fan and compressor go off. After approximately 10 minutes, listen in the freezer for sizzling and crackling sounds of water hitting a hot heater element. You must wait about 6 hors since you last thawed out the coils to be sure the thermostat has closed. If the heater is on, and the coils thaw out......replace the timer. If not, the problem is with the heater or thermostat.
Aug 11, 2009 | Amana Refrigerators
Door left ajar overnight,bottom emitter in freezer still cold&frosted,a motor running,is it fan or compressor,i.e.,which needs replacing,P.S.model3SRD21VW-how old is it!,worth replacing?
This could be several things, compressor, mother control board, defrost heater and defrost thermostat. I will help you find and fix your problem with the refrigerator if you like. Feel free to let me know, Sea Breeze
Jul 30, 2009 | Amana Refrigerators
Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Jul 23, 2009 | Sanyo Refrigerators
Freezer cutting on and off, not cooling
i would say it is a evaporator fan motor liocated between frezer and fresh food parts of fridge..but also could be a damper it self or damper motor
Feb 25, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Stopped Working
if theres a circuit board look for a fuse that probably blew out.
Apr 23, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Freezer is working/refrigerator works sometimes
No No No. The most likely reason that the evaporator fan is not running is that it probably uses the heater circuit for its neutral feed. I.E. In order for the fan to have 230v/115v it needs a zero voltage brought back through the defrost heater and defrost stat. I know this for a fact because I just did one today and have fallen for this scenario (ie bad fan motor) before. You need to check from ground(earth) to each side of the fan motor (which is easily accessible) and then across the fan motor windings. The chances are that you have zero voltage across the motor. The fan will also not run until the temperature of the evaporator coil has been brought below 0 'C (32'F) and this can take up to 20 mins (again speaking from experience). This is to prevent snow being produced after defrost. I would advise getting the engineer to come back if you have paid him money and do a proper job. Shorts in Amanas can happen but have not come across one yet. Hope this helps.
Aug 26, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ARS2464B Side by Side Refrigerator Logo
208 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
