SOURCE: single axel for Bell jogging stroller
good luck finding one. Mine also broke and I called Bell to see if they have these poarts available. As the stroller is no longer in production, they have no parts available. I found a used one in a Goodwill-type store and am currently using it for spare parts.
SOURCE: my jogging stroller shakes
Well, i'm not positive in this, seeing how I never had kids, but while jogging are you pushing down harder on the stroller? or you could look for smaller wheels to put it on, but then again you might have'ft to bend over to do it, and if the handle which you push is tall that has to do with force viberating the stroller
SOURCE: Baby Trend Jogging Stroller - Need Replacement covers
they have available parts as per their website. you can visit their nearest store branch or order online
http://www.babytrend.com/products_detail.php?CategoryID=0005.0002.0000.0000&LampID=948
SOURCE: fold stroller
Not sure how different this one is to ours but we have an older Dreamer Design double stroller and down by the front wheel there are two black plastic clips that you pull upwards while at the same time pushing two small depressable "buttons" that are in line with the main bars coming down towards the front wheel... once that's done you lift and push backwards at the same time, the whole stroller frame will move backwards (oh brake has to be on) and then once those main bars are free you can pull the frame towards you and then double it over back on itself...the rear wheels pull out by pushing the centre button and pulling on the wheel and they you're able to put it just about anywhere...hope that helps...Rob
SOURCE: My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
