Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
I have a Bissell power steamer power brush model 1697. The sprayer stops working after a 1 minute.
reddevil6
  • 1673 Answers
SOURCE: Bissell 1697w
First take off the belt cover on the side,
then turn it over, on the belt end of the brush roll, there is a red piece to hold in the brush roll, take out that screw and pull it off, the you can remove the end cap and cogged belt, Put the pump belt up thru the opening and around the bigger part of the pump pulley, grab the belt from the top side and put it around the motor shaft. Re-install the cogged belt, brush roll, cap and red lock.
Posted on Jan 06, 2008
  • 33 Answers
SOURCE: brushes not turning on 8920 2x Bissell
Brushes are switched on by lowering the handle which activates a micro-switch located inside the lower part of the machine. Vacuum must be running as well. The DC power for the brush motor comes from a Bridge rectifier located on the PC board located in the handle. I have drawings that might help you.
petedcurtis@gmail.com
Posted on Jan 18, 2009
  • 121 Answers
SOURCE: how do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
Posted on May 07, 2009
hmerchant110
  • 7191 Answers
SOURCE: need instructions for using 1697 power steamer
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Jun 14, 2010
hmerchant110
  • 7191 Answers
SOURCE: I need instructions for how to use a bissell power
Posted on Jun 19, 2010
SOLUTION IS LEAKING FROM MY BISSELL 1697 CARPET STEAMER WHEN IT IS STORED
you should always empty the steamer before you store it away it stops it clogging up.
Sep 13, 2012 | Bissell 1697-7 Powersteamer Pro Deluxe...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Brush motor quit
The beater bar belt is broken.
Nov 18, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
BRUSHES NOT TURNING AND MAKES A NOISE
my brushes do not turn on my 1697-7 powersteamer pro deluxe what do i do
Nov 11, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697w
Nov 07, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
108 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
