Question about Saeco Easy Espresso Machine
Water filter light
We replaced the water filter, but the little red light keeps flashing.  Does anyone know how to get it to turn off?
  • 515 Answers
Try to hold in the button for water/steam for 15-20 seconds.
Posted on Aug 03, 2008
Sunbeam cafe series EM 6910 coffee machine little red light keeps flashing
That's the low water warning, triggered by a black float with a magnet inside, in the water container.
The magnet inside the float in the water tank loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Nov 17, 2012 | Sunbeam Cafe EM6910
I have a refrigerator of Whirpool type 20RU-Dsybol and the symbol of the antibactreial filter (green) flashing what does this mean
Hi!!
The filter status light will help you know when to change your water filter. The light will flash and change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red OR water flow to your water dispenser or ice maker decreases noticeably. After changing the filter, reset the filter status light by pressing the button. The status light will change from red to green when the system is reset.
1. Press the eject button to release the filter from the base grille. 2. Pull the filter straight out. 3. Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4. Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed. 6. Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Good Luck!!
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 03, 2010 | Whirlpool GC5SHEXNS Side by Side...
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
Red light stays on after changing the water filter and running about 2 gallons through it
Light (select models)
To Reset Indicator:
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Saeco Easy Espresso Machine Logo
142 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
