Question about GE (PSS26MSRSS) Side by Side Refrigerator
Frost is building up in the GE GSS25 side by side refrigerator
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 21, 2011
GE gs22jepacc side by side refridgerator
Typically a frost build up would indicate a low charge. Partial freezing as evaporation happens too quickly in part of the circuit. Check the charge.
Nov 16, 2013 | GE Refrigerators
Refrigerator side not cooling. The freezer works fine. Its age is over ten years old. Model GE TFX22R.
Is there any frost build up on the freezer panel? If not, this could be a damper door issue. Check to see if air is coming from the damper, this is the vent inside the back left-corner of the fresh food side, assuming the evap fan is running. If you feel nothing, it more than likely is your damper door.
If you have frost build up, we're talking about a defrost issue then. Let me know!
Mar 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer frost
Make sure that the evaporator fanmotor is working.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS25 continuely has frost on cube chute preventin cubes from discharging. Have had doors replaced under recall but problem came back.
I had the exact same problem. My neighbor has the same refrigerator, and told me that there is a solenoid in the door, behind the panel where you select between water, crushed or cubed ice. You can carefully remove that panel to expose the solenoid, which is on the right side of the dispenser water line. I have the model GE GSS25. The plunger on the solenoid gets rusty buildup on the outside of it from the moisture and water splashing from the dispenser. You might try wiping the exterior of the solenoid, and working it up and down so that it moves freely. If not, it's a cheap replacement part you can order from GE. The solenoid shuts the trap door which opens when you get ice from the dispenser. If the solenoid plunger does not move freely, then the trap door hangs open, and warm moist air enters the freezer through the ice shute, causing frost.
Sep 16, 2009 | GE GSS25JEMWW Side by Side
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Sep 02, 2008 | GE GSS20IEM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
276 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
