Question about Ovens
Double Oven KEBS208SSS - Ovens
  • Ovens Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Mar 21, 2011
Smoking near top heating element upon initial operation
Some oil of some kind must've been on the heating element. No worries.
Feb 17, 2015 | KitchenAid Kitchen Aid KEBS208SSS Double...
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Ykemc308kmo oven fan noise
You are probably correct the cooling fan can wear out. You will have to order it by model number. They are a bit tricky to install depending on the oven, but not hard once you get to the fan area. Somke are behing the cabinet and you will have to puul the oven out and some are in the control panel area.
Nov 26, 2013 | KitchenAid "KEBS208sss Electric Double...
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
48 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
