Question about Apple iPod MA446LL/A MP3 Player
Ipod not working
I have a 80GB ipod .
I had to wipeit out to the factory setings.
Now that I have done this,
when I turn it on, it tells me to connect to 'your computer'
using itunes to restore.
so i do what it tells me to do
and it is no good.
i have tried a new itunes library and
still no good. can you help me?
Thanks!
Cliff
mmsccs@hotmail.com
  • mmsccs Aug 03, 2008
    Thank you for responding so quick!
    I'm using a PC. When I connect the ipod, it does not show up.
  • Paul Needler
    Paul Needler May 11, 2010
    Hi Cliff, are you using a Mac or PC? Also, in iTunes, when you do connect the iPod, does it ever show up?
    Problem Solver:
  • 9 Answers
No Prob Cliff,
Make sure that your iTunes is up to date from http://www.apple.com/ca/itunes/download/
(Apple keeps updating the Mac side often enough, I am sure there is the same for the PC). When you wiped it out the first time, it was on this computer, right, and using iTunes?
Here is an Apple Support document that will give you some things to try:
http://support.apple.com/kb/TS1363?viewlocale=en_US&locale=en_CA
Let me know if anything helps you.
Paul
Posted on Aug 03, 2008
Ipod 80gb silver, when i turn it on it has a RED CIRCLE WITH A RED CROSS INSIDE ON IT AND UNDERNEATH THAT IT TELLS ME TO GO ON .... www.apple.com/support/ipod and i've tried this but it was no help. The...
connect the ipod to pc
start itunes
when it detects the ipod in recover mode
click on restore button to restore the firmware
it will download and reinstall the firmware
if it isn't detected in recovery mode then simply click on update button when it is detected normally in itunes.
Mar 05, 2011 | Cameras
My ipod 80gb is saying apple.com/support/ipod
Try resetting it. Sometimes that's all it needs.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Feb 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
We are getting a message that the ipod touch is disabled, and it is telling us to connect to itunes. When we connect, it tells us to enter the passcode into the ipod, which is impossible when the ipod is...
I have a very easy solution for this. But let me warn ou that this will cause a permanent loose of all kind of data stored on your ipod.
Connect your ipod touch to your pc.
Hold both home and power button until it restarts and shows connect to itunes sign.
Now your itune will ask you to restore it.
After the proccess is done you will have your ipod unlocked and back to its factory settings
Dec 29, 2009 | Apple iPod touch
80g ipod classic won't unlock or charge,and itunes won't
My 80GB Ipod classic recently froze. I took it to Apple store and the guy press the Menu and Center Button. Hold them until the APPLE logo appears twice. Then release the button.
Voila, my Ipod work again, no missing data
Jul 22, 2009 | Apple iPod classic MP3 Player
My ipod classic 80GB
SORRY BUT YOU GOING TO HAVE TO FORMAT THE IPOD,GO ONTO THERE WEBSITE FOR DETAIL INSTR
Jul 03, 2009 | Apple iPod classic 6th Generation Digital...
My 80gb ipod apple logo want turn off
It is most likely frozen I have the steps below on how to reset the ipod. This should resolve your issue completely.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If this does not resolve your issue please let me know. CHEERS :)
Apr 24, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod 80gb black
The only other solution is to restore your Ipod to factory settings. Reload the songs back up. Make sure the updates are done.
Sep 06, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 6th Generation won't connect to VM9412
All I can tell through my searching, is that the Jlink only works on gen3-gen5 ipods. I have a gen 6 80gb classic, and while I can hear the audio from the movie playing, I have no video. Music plays fine.
Aug 15, 2008 | Jensen VM9510 Car DVD Player
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
