Question about Car APS25CH Prestige 2 Button Remote Security System with Shock Se
I have a Prestige APS25CH system installed in my Jeep Cherokee. I cannot turn off the alarm with either the remote or the valet switch. I get a constant alarm and no alarm LED. Opening the door stops the siren, and turning on the ignition stops the siren, but no matter what I do, the car won't start...the ignition, door locks, and power windows are all dead. I suspect a major failure, but can't even start the car to take it to a shop.
  • 3 more comments
  • bobmacnicol Mar 21, 2011
    Thank you for your reply. I have the programing instructions, and have tried to reprogram the remote. The system won't reprogram, and doesn't even seem to be responding to either the remote or valet switch.
    That sounds like something would fit my problem. I'm am trying to de-power the whole system, so that I can at least drive it. If I figure out how to cut the power to the system, will I then be able to start the engine?
  • bobmacnicol Mar 22, 2011
    I understand that, I've already tried the battery reset technique, so I know that won't work. But my car is at my home, and because of this problem, I can't start it to drive it to a shop to have someone use the "specific tool".
    So my question to you is: If I find the main power wire for the system, and disconnect it, will I then be able to start the car?
    I have the wiring diagram. I see that the yellow wire is probably the power-in wire. I guess I'll disconnect it and see what happens. Since the car won't start, it can't be any worse than what I have now.
  • bobmacnicol Apr 07, 2011
    ZJLimited,
    Since it was rather strange, I thought you might like to know the outcome of my problem. It was the Jeeps battery. My remote had developed a hair-trigger, and apparently just before I tried to start the engine, I accidentally hit the remote button. Then when I tried to start the car, that killed the battery, and with the battery gone there wasn't enough voltage available to shut off the alarm. After two days of head-scratching I replaced the battery, and was able to shut down the alarm with the valet switch. Whew! That one had me goin'!
    Bob
  • 17,970 Answers
Sound like a re-programing problem; if your ssytem is underwarranty, contact your dealer alarm.
Its possible that you find additional details in this link: lesscoelectronics.com/Articles.videos
Keep su updated.
Posted on Mar 21, 2011
  • 3 more comments
  • ZJ Limited
    ZJ Limited Mar 21, 2011
    Them, its possible that you need to re-synchoized with the theft vehicle module, to do it, need visit your dealer, other way, could lost the warranty.
  • ZJ Limited
    It's not as simple as "reset" the vehicle's ECU (by disconnecting the battery connections), you may need a specific tool to reset the security module of the vehicle, insist that before doing so ask someone you trust in workshop alarms.
  • ZJ Limited
    ZJ Limited Mar 22, 2011
    I suggest ask for the aftermark alarm wiring diagram or check in the repair manual from your Jeep Cherokee; what year is your Jeep? I'll try to look some electrical diagram.
  • ZJ Limited
    OK, keep us updated.
  • ZJ Limited
    ZJ Limited Apr 07, 2011
    This is good news. I appreciate Fixya us to solve their problems and get clues to their solutions. Remember qualify for our help.
I lost remotes,how do i bypass alarm?
Locate the valet/override switch. You may have a push button LED or, it may be located under the drivers side of dash. Turn igniton on press and release push to manually override alarm. Turn ignition off then, back on. Press and hold push button for approximately 5 seconds to put alarm in valet.
Jul 18, 2012 | Car APS25CH Prestige 2 Button Remote...
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
How to put the prestige aps25ch 1200 foot range in valet mode
ALRMM SHOULDN'T GO OFF IN STORMY WEATHER UNLESS U GOT A LEAK SOMEWHERE OR YOUR SENSOR IS TO SENSITIVE
Jul 04, 2010 | Toyota Vehicle Parts & Accessories
The alarm wont let my car start. i turn the key and now response. how do i get the engune out of sleep
look for your valet switch. It should be under the dash(a little red button). put the key in the ignition, turn all the way until the instrument cluster lights on, then press on the valet switch for a couple of seconds until you hear the alarm chirp. You're now in valet mode and it should be ok to start the cart.
Oct 28, 2009 | Audiovox Prestige Code Alarm Remote Alarm...
My audiovox prestige alarm only does slient. How do I get it back to chirping ? model # aps02bt2
Simple....
1st turn the ignition key on than off
2nd within 10 seconds press and release the valet button switch 3 times.
If you did it right you will hear 1 chirp to indicatate the chirps are back to irritate and ******** all your neighbors.. just kidding. good luck
Jul 31, 2009 | Car APS02BT2 Transmitter for...
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
The car arms but the alarm does not chirp
try turning your key on and flip the valet switch, your alarm is most likely in valet mode (youll know cause the led stays on) if that doesnt work, turn the key on and off then toggle thye valet switch 3x and that'll turn off silent mode. Good luck, Martin @ lessco electronics
Feb 25, 2009 | Car APS25CH Prestige 2 Button Remote...
Car APS25CH Prestige 2 Button Remote Security System with Shock Se Logo
146 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
