Question about Kitchen Ranges
Smeg oven 10 or 11 years old. No Manual. Model number is SA10X... rest of model number worn off. Single 60cm stainless underbench. Where can I get a manual?
3 Suggested Answers
SOURCE: Re Smeg 60cm electric
I have one for sale I am jus putting it up on ebay buy it and replace yours.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110291356746
Posted on Sep 20, 2008
  • 197 Answers
SOURCE: My oven is not heating
check your element with a continuty meter and your cut out stats
Posted on Oct 03, 2009
SOURCE: smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Posted on Nov 13, 2011
Oven slow to heat , oven burner goes on and off a lot, oven igniter glows....broiler works fine
Hello. I need the make/model number to help you accurately. It sounds like the bake ignitor is worn out and not consistently igniting the gas. How old is the unit? If it has more than a few years on it, the ignitor can wear--it might glow, but not enough to ignite gas. Remove the racks.Remove the bottom cover of the oven(usually there are 2 screws, right and left side at the rear, inside the oven. There usually will be a heavy steel flame shield held on by a single nut underneath the cover. Remove this shield. This will expose the ignitor(called a glow bar). One of the classic symptoms of a worn bar is that the center of the glow material will turn bright orange but not the rest of the resistive material. Also, you can test the viability of the bar using a meter. Normal amp draw on either of the 2 wires connected to it should have approximately 4 amps. Use a clamp-on voltage/ohm meter set to amps. Under normal conditions, the electric gas valve senses the current draw and will open, letting in gas to ignite. From activating "bake" to ignition *usually* takes 20 to 30 seconds. If you find yours is worn, HANDLE THE REPLACEMENT GENTLY. Don't knock it, drop it, or touch the resistive material. It is FRAGILE AND BREAKS EASILY(ask me how I know this!)The mount screws(usually 2) can become seized due to heat. Take your time removing them. Another symptom of a worn ignitor can be the "WHOOF" sound of too much gas building up in the oven prior to ignition. I've seen oven doors knocked open by too much gas saturation suddenly igniting from a slow glow bar. I hope I helped you!
Sep 07, 2015 | Kitchen Ranges
Bellind duel fuel stainless steel cookerHow do I restore numbers that have worn away on my oven temperater guide
Staedtler fineline permanent marker.
peel off letter sheets from craft shop.
contact manufacturer ask for transfer to be posted to you
Mar 02, 2015 | Belling FSDF60DO 60cm Freestanding Dual...
Want to download a user's guide/manual for an old wall mount double oven from the 70's. I believe it is a P7!
If im not mistaken the P7 was a General Elecrtic oven?
the FULL exact model number is needed to downlaod a manual and chanches a manual for a30- 40 year oven will not be on the net. If its GE find the full entire model number and go here to try to download that manual http://www.geappliances.com/service_and_support/literature/
Aug 13, 2011 | Kitchen Ranges
I want to set the time on my smeg oven but do not know how to
with model is your oven?
In the link bellow you can find the user manuals for varius models Smeg has to offer.
http://www.smegappliances.com.au/ProductManuals.aspx
Mar 01, 2011 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Override auto shut off
Since you have the model number, get the serial number and look online for the instruction manual. They might charge you for it, but you will have it. MODEL AND SERIAL NUMBER BOTH, ARE A MUST BEFORE YOU LOOK IT UP. Or call Maytag to get another one.
Apr 01, 2010 | Maytag MGS5875BDS Stainless Steel Gas...
Smeg suk91mfx shelves not fitting anymore on oven.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
I have a smeg SA360X oven. how can I cook without fan force. Cannot understan dials
If this is because the labels have worn off the dials then manuals can be accessed from http://www.smegappliances.com.au/Category-18-Single.aspx
Select the model (closest is probably the SA304X-8) and then download the 50 page manual in pdf format (slow).
Waggabruce
Jun 24, 2009 | Kitchen Ranges
Re Smeg 60cm electric oven model SA370 EB/1. I need new door glass and rubber seal for glass door.
Jun 23, 2008 | Smeg Kitchen Ranges
Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Mar 15, 2008 | Kitchen Ranges
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
