Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
How to change mower blades - Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
    New Friend:
  • 18 Answers
Fine a way to stop blade from turning, put a socket with long handle and turn countercock wise, some will need a wench on nut at top of shaft to stop blade from turning, torque to 60 # on most 50" or lower width mowers
Posted on Mar 07, 2015
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
How do i change the mower blades on my honda hru19d
Check this site for changing mower blades. Seems straight forward:
HOW TO CHANGE LAWN MOWER BLADES
Feb 11, 2015 | Honda Garden
How to change blade on a troy-bilt mower model 12a-264u011
Turn mower on it's side with the carb facing up (otherwise fuel will pour out of the carb) There should be one bolt holding the blade on, remove it and the blade will come off. Install new blade in reverse order. Use an impact wrench if you have one otherwise use something to keep the blade from rotating when removing the bolt with a wrench.
Oct 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Engine locked up while changing the blade and mower leaned over carb side was up it will not move either direction
blade brake is engaged unhook it and try turning the blade by hand should work
Aug 14, 2014 | Toro Garden
Husqvarna instructions
On ZTRs you raise the whole front of the mower including the deck. To prevent the blades from while loosing and tightening you use a wooden block between the blade tip and the mower deck.
When retightening the blade torque the blade bolt to 45-55 ft/lbs (60-75 Nm).
Jul 30, 2014 | Husqvarna RZ4824F 48" 24HP Kawasaki Zero...
I have a yardman 6.5 h,p.push mower. How do I drain the oil to change it and how do I remove the blade to sharpen it?
I am assuming you have a Briggs & Stratton motor. If you have a "yardman" engine the procedure is still the same.
Changing the oil: Your mower does not have a drain plug on the bottom of the mower. Remove the dipstick and tip the mower over on that side. Let the oil run out and leave it tipped over for 5 minutes or so to get all the old oil out. Replace it with 22 oz of good 10w30 or straight 30w oil. I personally use Mobil One and change it once a year.
Blade: With the mower turned over you will see a bolt in the center of the blade. Remove that bolt and the blade will come off. Use a box-end or socket so you don't mess up the nut. It may be hard to loosen at first. Inspect the blade. If it has not large nicks or the dings and the back of the blade is not worn too much (the curved part) you can sharpen it with a file or grinder. Try to take the same amount off of both ends of the blade. (If you want to know how to balance the blade let me know)
If the blade has large dings, is bent different on one side more than the other, or parts of it have cracks, replace it with a new one.
Don't forget to change the air filter.
Jan 04, 2011 | Garden
How do you set the mower blade height on a riding mower. The mower deck is set by the height adjuster but how about the blade
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Jun 18, 2010 | Garden
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Oct 13, 2008 | Poulan "Poulan" Push Mower
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
136 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
