Question about Fujitsu ScanPartner fi-5015C Pass-Through Scanner
Cannot load drivers for Fujitsu fi-5015C, once loaded, computer restarts and when windows comes back up it states there is new hardware that needs software downloaded, rather than starting the new hardware install process.
    Problem Solver:
  • 12 Answers
Kindly download the new drivers for fujitsu Fi-5015 scanner from the below link and if solved/unsloved let me know i will guide you to solve this porblem,or mail me in felixsimon22@gmail.com
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
regards
felix
Posted on Mar 23, 2011
Proper wiring my hp pavilion p6 2330pc and my hp printer
http://h10025.www1.hp.com/ewfrf/wc/product?product=5296967&lc=en&cc=us&dlc=en
1) DO NOT connect printer to computer!
2) Put the Installation Disk for the printer, in the optical drive of your computer. (Comes with the printer)
If you do not have this disk, post back in a Comment.
You will download the software from HP Support.
I need the printer model name, and model number.
Also what Windows operating system you are using.
(It cannot be assumed what Operating System you are using.
May not be the one that came with the computer)
If you have the Installation Disk, load ALL software.
(One example; HP Photosmart Full Feature Software & Drivers)
[Driver: Small piece of software that allows the Operating System to communicate with a device
The device is the Printer. The O/S wasn't stated.
The Full Feature software covers all the software the printer needs.
If it is a unit that can Scan, Copy, Print, and Fax, for example;
all of that software will be loaded ]
ONCE the software is loaded, restart your computer if not asked.
After Windows has loaded again, let the computer run for a few minutes.
Now restart the computer.
(WinXP example; Start > Turn Off Computer > Restart)
Plug the USB cable from the printer into the computer.
Turn the printer on.
After a few seconds you should get a pop-up in the taskbar,
"Found new hardware device"
And perhaps another one,
"Found HP XXXXX device "
(X's stands for model name/number of printer)
IF,.......you have connected the printer FIRST, then attempted to install software -> This = NO.
You can get a driver conflict.
Post back in a Comment if this is what you have done.
[When a device (Printer in this case), is connected, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will pick from it's THOUSANDS of generic drivers.
Now you you install THE drivers needed, and there is a driver conflict;
Windows: "Which ones do I use? These or THESE?" ]
Post the printer model name, and model number. This can be found on the Back of the printer.
(This is the type of USB cable end, that usually plugs into a printer,
http://en.wikipedia.org/wiki/USB_connector#Cable_plugs_.28USB_1.x.2F2.0.29
Type B. It is also a Male plug. So it's a USB B Male.
Square shape with two corners cut off.
The USB A Male connector is the one that plugs into the computer.
(Type A)
Rectangle shape )
Regards,
joecoolvette
Apr 07, 2013 | HP Pavilion Computers & Internet
Im getting black lines on my paper.
YOU NEED TO GET THE SCANNER SERVICED TO REMOVE THE BLACK LINES AS DUST IS INSIDE THE GLASS
Mar 17, 2011 | Fujitsu ScanPartner fi-5015C Pass-Through...
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
Where can I get fujitsu c2230 sound drivers?
For Fujitsu C2230 Notebook PC's with either Windows 2000, or Windows XP, right here on Fujitsu Support,
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Whoops FAILED! Tried to give you a direct link to the Drivers page.
(Have you ever seen those vid's of Failed? Like the skateboarder who went down the pipe railing, and wound up straddling it?
Ummm, ..err,...Never mind!)
Let's go the long way instead.
http://support.fujitsupc.com/CS/Portal/supporthome.do
On this page go to the right hand column, and under the white - Mobile Support - heading, left-click on - Driver Downloads
On this page you will see three headings at the top.
Select Product
Select Series
Select Model
Under Select Product click on - Notebook
Now under the Select Series heading, scroll the side bar down, and click on - C Series
Finally under the Select Model heading, click on - C2230
Click on Go, to the right of the arrow in the red square.
You will see the - Windows 2000 Compatible Drivers - heading, and
Windows XP Compatible Drivers - heading.
Go to the operating system you are using.
Left-click on Audio
Click on Accept on the next page.
In the small window that comes up on the top right, left-click on -
Save File.
If you do Not have your downloads, set to save to your My Documents folder, this file will go to your Desktop screen.
(My Documents for Windows XP. Documents for Vista.
Windows XP? Click on Start>My Documents)
The name of the file is C2230_AUDIO_REALTEK_V5.10.00.3696_2KXP.EXE
When you see the file name, Double-click on it.
The Installation Wizard will come up.
Follow the easy instructions.
(Basically just click on Next, Next, and Finish.
If you are asked to restart your computer, do so.
If you are not asked to restart, close all windows until you are back to your desktop screen. Restart your computer.
Start>Turn Off Computer>Restart)
The above, is stated that you are using your Fujitsu Lifebook C2230, to download the Audio, (Sound) driver.
If you are using another computer to download this Audio driver, download it to the computer, then right-click on the Audio file name, and burn it to CD disk.
Take the CD disk, and install it in the Fujitsu Lifebook C2230 optical drive, with the laptop on, and Windows loaded.
If your Fujitsu Lifebook C2230 has Windows XP, left-click on Start, then My Computer.
Double-click on the optical drive that the CD is in.
Follow the easy instructions of the Installation Wizard.
If you have problems, or further questions about this, post it in a comment.
Dec 24, 2009 | Fujitsu AMILO D-7820 Notebook
Flashing U light
try resetting the device and power fleeing by pressing power button in on condition for 30 seconds this fix the problem
Sep 03, 2009 | Fujitsu ScanPartner fi-5015C Pass-Through...
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
S. Mohan, Chennai, India
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Emachine t3112 only work in safe mode
you need to run the new hardware wizard as there are differnet drivers needed for the mb
Dec 19, 2008 | E-Machines T3112 (RBT3112) PC Desktop
Fujitsu C6387 slow to start
What may well be happening is that a peice of hardware, eg usb ports, network adapter, graphics driver or similair is struggling to find the driver for it and is hanging the boot up. It could also be a memory failure or a bios failure as the memory used by your system takes over after the first 64KB of built in bios memory. Start your laptop in safe mode (press F8) on start up, as this will load up with only the needed drivers, if it boots up quicker it may well a driver fault, it is then a process of illimination.
Apr 20, 2007 | Fujitsu Siemens LIFEBOOK C6387...
Fujitsu ScanPartner fi-5015C Pass-Through Scanner Logo
196 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
