Question about Dell Computers & Internet
The start button turns itself off both when plugged in and by batteries
    Guru:
  • 571 Answers
Have you tried removing the battery in the Laptop? I mean powering up the computer without the battery on it? You just have to use the power cord on it. In this way, we can check which one is having a problem.
There are three possible problematic parts in the computer. 1. Power cord, 2. Battery, 3. Motherboard.
What you need to do is to isolate the problem. So, try turning on the computer by using the power cord alone. Let me know if what happens later on by leaving a comment in this post and I'll attend to you as soon as possible.
Posted on Mar 21, 2011
New Computer Shuts Itself Down
Call DELL support. Doesn't sound normal. There is Standby and Hibernate modes; neither of which would require you to unplug and plug-in the power cord in order to start the machine.
Dell support will have you run the Dell diagnostic at startup which will detect hardware problems. Or you could run it without calling...
Unplug power and remove battery
Press and hold power button 20 seconds
Replace battery, plug power cord in
Hold down the "Fn" key (to left of space bar)
Turn power button on while still holding Fn key
When diagnostics begins, let go of Fun key
Note any errors; let Dell know your findings
Jan 16, 2014 | Dell Inspiron Computers & Internet
Cannot turn on
from https://discussions.apple.com/thread/2462356?start=0&tstart=0
Try pressing SLEEP/WAKE button and HOME button *at the same time* to force it restart for 2 or 3 times and see if it can turn on. Sometime it's just turn off by itself (happens more frequently for me esp when the battery is low) and we have to force it to start again.
Hope this helps,
Jan 03, 2014 | Apple iPad 64 GB WiFi
My tablet iconia wont start
There should be a tiny reset button or pinhole (use a straightened out paper clip). If reset button/hole itself does not work, try pressing it while holding down the power button at same time. Otherwise, it sounds like you have a battery/charging issue (try another charger cord if available).
Dec 02, 2013 | Acer Tablets & eReaders
Keeps turning itself off
sounds like a dogy power button, battery or cud be software problem... try plug it into a comp or laptop n see wat happens...
Apr 23, 2013 | Apple iPhone 3G
My computer turns on by itself and does not display anything
disconnect the power adapter and battery
2) make a HARD RESET 3) press the button power and hold by 60 seconds.
3) connect the power adapt +battery and try again.
4) if the problem persist. test the power adapter for short and repair or replace.
restart pressing the f8 and go safe mode with network, and RUN the scannow.
5) Run the software coming with the computer.too
God bless you
Mar 25, 2013 | HP Pavilion a264w PC Desktop
Asus x83v won't boot up
Unplug the machine, remove battery, leave the battery out, plug in the machine, try to boot normally. If the fails unplug, plug in, push the on/off button and IMMEDIATLY start tapping the F-11 REPEATEDLY. Enter restore/recovery section select a date before this problem started and restore. If that fails do a system recovery to factory settings. Or if you have a Windows Vista repair disk, Windows Vista Install disk that you can use to repair
Nov 12, 2012 | ASUS Computers & Internet
Phone will not turn on with white light
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 01, 2012 | Motorola Mobility RAZR V3
My screen is black after powering on. i have
Try an external monitor, if still nothing, power down, remove battery / /tap start button to de energise system / remove / replace ram stick (s).
If stil no go may me mobo / faulty ram(assuming there is NO posting beep) / faulty CPU.
If ext monitor works then prob with monitor itself.
Get moniotr wiring / ribbon plugs checked.
Mar 26, 2010 | Dell Inspiron 1525 Notebook
Computers turns on and turns off in about 5 seconds by itself
may be your reset button is pressed on....so you better unscrew your computer and then remove the plugged in botton that is lined from reset button (u can follow the layout diagrams inside the computer)... ..i think it may help you ... later you can take out the pressed reset button as well....
Apr 12, 2009 | Compaq Presario V5102NR Notebook
Laptop not being powered on
Did you get the battery checked? OR maybe it's an issue with the PowerJack connector on the motherboard...have it checked ASAP.... Also take out the battery and plug straight from the wall jack using the Adapter to ckeck if power is coming.
Sep 16, 2007 | Acer TravelMate 529ATX Notebook
Computers & Internet Logo
37 people viewed this question
Alun Cox
