Question about Maytag MAH6700AWW Neptune Front-Load Washer
Fab.softener disp. does not work?.....Chris - Maytag MAH6700AWW Neptune Front-Load Washer
    Brigadier General:
  • 6,277 Answers
It could be that it is the conditioner/softener tray which needs a thorough clean by following these guidance notes,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of the above should enable you remove it
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
Good luck,
John C
Posted on Mar 21, 2011
Washing machine is not using fabric softener!!!!
IS IT FRONT LOAD OR TOP LOAD. I HAD A PROBLEM WITH MY FRONT LOAD. IT HAD A LOT OF BUILD UP SO I TOOK OUT THE WHOLE DRAWER WHERE FAB SOFTENER AND DETERGENT WENT AND SOAKED IT IN HOT WATER THEN CLEANED THE INSIDE COMPARTMENT. IT JUST GOT STOPPED UP
Jun 21, 2012 | Washing Machines
It did not come with the manual. How do you use the Fabric Softener Dispense?
just put the softener in the disp. it will dispense in the machine automaticaly
Sep 02, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric softener drains AFTER the wash is finished or not at all.
take the front filler cup out by opening and then int he back is a grey push down lever. the system will then come apart and. clena the long tube that is part of the fab soft in hot water. this will work.
Dec 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do i get the detergent/fab. softener tray clean? It wont drain because of the softener build-up.
Softener is a combination of wax, transport solution, and perfume.
What clogs up the dispenser is the wax.
Try pouring very hot water (close to boiling) down the path that the softener takes to get to the tub. This will melt the wax build up and wash it out.
You will need to do this multiple times to get all the wax melted.
Don't use water so hot that it melts the plastic parts.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spots on clothes
Chris your agitator problem is repairable. remove the fab softener cup and the cap on the agitator down inside the opening you should see 4 pieces that look lik a tear drop is my best description for them your are wore out and do not engage when the agitator agitates replace them and you'll be good as new.
Mar 19, 2009 | Roper RAS8445KQ Top Load Washer
Water in fabric softener dispenser
you will need to clean out the tray thoroughly and then remove it to clean out the holes above it with a stiff washing up brush. these get blocked up and dosnt help force the fab cond out.
Mar 16, 2009 | Frigidaire ATF6000ES Front Load Washer
The fabric dispenser does not release softener into the tub
it may be the water supply to take the fab cond in is either blocked (holes) above the dispenser or the water valve is faulty.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Softener tray filling with water
open the dispenser all the way,place your finger towards the back left of dispenser.you should see a tab,depress the tab and pull entire dispenser cup out.the bleach and fab soft part of the disp has a removable tray.clean all pieces out including the long shafts on the insert.you will more than likely find a build up of softener,this breaks the siphon and does not allow the water to drain out.good luck
Sep 23, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
