Thetford Norcold® Model DE0061 Logo
Posted on Mar 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My compressor runs for 3 seconds - then shuts down for 3 minutes - then runs for 3 seconds
Anonymous
Level 3:
  • Thetford Master 43,501 Answers
  • Posted on Mar 21, 2011
Anonymous
Thetford Master
Level 3:
Answers
43501
Questions
0
Helped
10843724
Points
101584
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2answers
Until now this unit has never had the compressor run without the fan. Is the compressor running without the fan a problem? If so, what can I do to correct it?
Possibly a tstat issue. Run system until satisfied, once satisfied indoor fan shuts down compressor still runs remove tstat face plate and see if compressor shuts down. Another issue could be a sticking contactor for compressor. With a meter you could check at the contactor to see if you lose your 24volts for cooling but contactor remains pulled in.
A/C compressor shutting on and off at different intervals
When cu shuts down does the contactor release?When compressor shuts off are you still getting 24 all the way to contactor?? If system shuts down with contactor pulled in it's a high voltage issue. If contactor lets go then you know it's a low voltage issue. Possible short, check tstat wire for rodent damage. Tighten high voltage wires in disconnect, be safe!!
Kenmore model 795.78544.804 refrigerator and freezer not getting cold enough
If there is a capacitor running the compressor, replace it. if that does not solve the problem, suspect the compressor failing.
3helpful
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
1helpful
Goodman GSC130361DE premature shut off
im not sure what tstat you have? if you still have your tstat book it well tell you how to set it up. may be it was not programed when installed. i hope that helps
3 year old VUAR141 cools but only gets down to 16C at coldest setting(spec is 4 to 14 C)Compressor and cooling fan only run for approx 3 minutes then shut off for 20 minutes or more before restarting....
Those symptoms you describe indicate a compressor that is "short cycling", if it is indeed starting and running for those 3 minutes. Is the evaporator cold for those three minutes as well? Many times people think its running, then shutting off, when in fact it is only trying to start. Without proper tools you cant test compressor, but it might be worth finding out from a repair service if its the compressor or the compressor starter, the latter of which is much much less expensive.
Assuming the other motors on the cabinet are running, you've narrowed your problem down to 2 things, the compressor itself, or the start device has failed. Without the proper tools you wont be able to test the compressor first. My advice, go to repair clinic . com, see what a starter will cost you, if you can find a repairman to check your compressor for cheaper than what it costs to buy starter, well there you go. Either way, if its the compressor thats bad, you wont want to spend the money to replace, unless you have a built in worth several thousand, or physical constraints of kitchen prevent you from buying new fridge.
Visit: www.FixMyFridge.net for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
1helpful
OUT SIDE UNIT SHUT DOWN IN HEAT MODE, WHEN YOU FIRST TURN IT ON IT RUNNS FOR ABOUT 30 SECONDS THEN BOTH THE COMPRESSOR AND FAN SHUT OFF FOR APROX 3 MINUTES {LARGE LINE STARTS TO GET WARM} AFTER 3 MINUTES...
Hi, You have a heat-pump, this I do no. The reason it is shutting down from how you have explained it to me, is the compressor is shutting down due to high pressure and it is going off on the internal overload. When the compressor cools down, it starts back up and runs again. As for the large line getting warm, this is normal for a heat-pump as in the summer this line will be cold. The reversing valve changes over the flow of freon and the flow goes in the other direction. Back to you're problem. The service tech is bleeding off freon because he is apparently showing with his gauges it is over charged? This will cause it to draw to many amps and shut off. Has this compressor been changed out recently? Or maybe freon added due to a leak? He is doing it because he is thinking it is over charged. It may be some if it runs for a few hours after it is bled off. Did you notice if he clamped his meter around a compressor wire to check the running load amps? If so, that's what he is doing. I would say this unit had work done on it recently or correct me if I am wrong. The condenser fan motor should not shut off with the compressor, it should run all the time even if compressor shuts off on internal overload, believe me!! The fan is wired separate from compressor. The only time this fan shuts off when heat is on, is when it goes into defrost, and compressor keeps running. For the compressor to run for only 30 seconds and shut off, and then back on in 3 min, on for 5 seconds and off again, sounds to me this unit is short cycling due to being under charged. It is strange it runs after he bleeds freon off for a 1/2 a day. As far as the fan shutting down to, and I would like you to get back to me, if the compressor was changed at some point, the fan wiring was connected to the contactor load side, so it shuts down when compressor shuts down. One fan lead is on the wrong terminal of the contactor. If this is the original compressor, this could have happened at the factory, I have seen this before. The tech should have seen this!! Going on and off this fast, would not cause the compressor to get hot enough to kick off and cool fast enough to come back on that fast! Sounds like low pressure. I don't like to knock other techs work, but this unit is not being checked properly. Without me being there to install my gauges and amprobe, all I can do is tell you he is wrong with his solution, way off. Heat-Pumps are much more tempermental then a split a/c only.What to do is call them back out and request a different service tech, or the service manager. This will be no charge to you! You should be reimbursed for the last call. E.P.A. allows us to only loose minimus amounts of freon installing our gauges also. It is forbidden to bleed it into the air. He could be fined $25,000 the 1st time!! It also sounds as though you have a problem in the defrost board that would cause this. Please call them back out and don't feel bad about it. This is you're right! Tell them about the fan also as if it is going off on high pressure which I think not, the fan would stay on. I know this is long but I want you to understand what is going on. I do this for a living and know whats up! I am a Licensed contractor in this field. Please keep me posted. I will be waiting to hear back.
Sincerely,
Shastalaker7
1helpful
2answers
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Compressor shuts down 59516.531G
Is the compressor too hot to touch when it shuts down? This would indicate a low charge
Fridge compressor problem ?
Seems to me you have a faulty cold control. (behind the temp control).Not too expensive , about 40 bucks.
Top Thetford Refrigerators Experts
john h
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
