Question about Maytag SDE2606 Electric Dryer
My Maytag dryer is approx. 15 years old. I have had no problems until yesterday. The dryer blows cold air -- no heat. Can you advise what the problem could be.
    Problem Solver:
  • 5 Answers
It could be just a breaker if its a 220volt. Check your breakers first and clean you exhust tube!
Posted on Sep 03, 2011
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Maytag dryer MDE6000 is only blowing cold air.
Electric dryers run on 220 volt, it is usually a double breaker at your main panel, however, depending on the electrician and how old the wiring is you might have two breakers, so start there first. If not, there are several parts to this dryer. It could be an element, a thermal fuse, high limit thermostat, or as simple as a burnt wire. Most important please turn off power before working on this.
The other thing that most people forget to check is the outlet pipe or vent pipe. If they get blocked, when the heat turns on, and it is blocked, the dryer will detect it and immediately turn off the heat but the drum will still turn. Bed Bath and Beyond has a dryer vent clean out kit that hooks to a shop vac.
Jan 09, 2009 | Maytag MDE6000 Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
How do I troubleshoot drying problems ?
could possibly be thermostats or heater if its just blowing cold air
Feb 11, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag SDE2606 Electric Dryer Logo
80 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
