Question about Air Conditioning and Heat for Mahindra Scorpio
Hello , i have mahindra scorpio 2006 crde run 50000 kms. the air conditioner is not working. the ac gas is ok and perfect 830 gms. compressor is getting engaged . but the blowers arent giving cool air . even the cooling coil is not cooling. the service centre people could not diganose the problem.
    Sergeant:
  • 259 Answers
You might have a blockage in the capilary tube or the compressor maybe be tired and can't build up the pressure.
Posted on Mar 21, 2011
Scorpio 2007 crde suddenly stopped while running on high rpm .and after few seconds vehicle start when cranking. Also black smoke comes out from exhaust .what will be the problem.
Black smoke emanating from exhaust indicates carbon and a lack of complete combustion of fuel Could be caused by too much fuel entering cylinder, weak spark, choke still on, clogged air filter, etc.
Aug 30, 2015 | 2006 Mahindra Scorpio 2.6
Mahindra scorpio crde is having pickup problem.The rpm meter doesn't rise above 2
The RPM meter is fully electronic and when it goes haywire, generally it's a problem with electrical current...
1. Grounding wires
2. Alternator
3. Dying battery
In my case, the alternator became gunked up with oil (from the pump that sprung a leak on the connector) and started destroying itself... the RPM's would be fine, then jump, then show lower than expected...
Check if the battery light periodically comes on very dimly while driving as well (almost for sure an alternator problem then)
May 29, 2014 | 2007 Mahindra Scorpio 2.6TD
Mahindra scorpio 2002 model crde engine oil coming to air separator n turbo inlet from oil sump
Hi
Turbo cars do drag some oily residue through the inlet system and, if the hose seals are worn, wil drip oil. This is all ok..just clean up the hoses and fit new seals. Make sure you always flush engine oil and use a new oil filter with the CORRECT engine oil.
If the airways are not correctly serviced, air mass meters, sensors, throttle body, egr will all get clogged up.
Regular service saves money.
Cheers
Roger
Apr 21, 2014 | Cars & Trucks
Free Online Repair Manual Mahindra Scorpio
I have Scorpio SLX Crde 2.6 temperature gauge not working what can i do
Aug 25, 2013 | Cars & Trucks
Mahindra pick up turbo diesel 2.5 engine timing diagram
How to get all mahindra engine timing mark diagram
Apr 15, 2013 | 2011 Mahindra Scorpio
In an inline 4 cylinder 8 valve scorpio 2006 crde engine having 1-3-4-2 firing order which valve is first - the outlet or the inlet
from the belt side first valve is inlet second valve is exhaust..bigger valve is inlet small valve is exhaust also you will have a black colour in exhaust valve stems...
Feb 28, 2013 | 2011 Mahindra Scorpio
Engine light comes on frequently and ther is drop in engine power or sometimes it stops too
have you tried changing your oil filter and all of your gaskets also you have sensors all over you engine you myt wanna try checking them out
Dec 05, 2012 | Cars & Trucks
My mahindra scorpio a c is not working
fuse blown? motor blown? or computer problem! could be the switch to!
May 16, 2012 | Air Conditioning and Heat for Mahindra...
Air Conditioning and Heat for Mahindra Scorpio Logo
327 people viewed this question
Top Mahindra Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Mahindra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
