Question about Ruud Central System Air Conditioner
It will not heat unless on emegency heat or it will not cool, but fan will work. What is the problem?
    Guru:
  • 683 Answers
Sounds like low on freon.
Posted on Mar 21, 2011
I have a 1999 buick Lasebra the heat or fan is not working what could it be
Well it could be any one of a few things ! There are two blower motor relays , two fuse's an the blower motor resistor, but wouldn't think that is the problem unless you have high speed blower operation ! But then again don't know if we are even talking about the same fan ? heater fan not cooling fan ?
Feb 20, 2015 | Buick Cars & Trucks
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
No heat for me and my daughter 201 ford taurs everything you can think of has been done to this car please help
i hate no heat. ford taurus 2001 are a problem sometimes with heat issues.on the firewall there are heater hoses that get clogged,pinched,and sometimes it's just a bad heater core. you said everything you can think of has been done?[replaced heater core? flushed the radiator? are the cooling fans coming on? is radiator full of coolant? have you took the cap off to be sure?like i said,i hate no heat. i'm still thinking.thermostat new?the blower works but only blows cold air?ok if thermostats good,radiator is full,blower works,radiators full,cooling fans coming on, no engine overheating but temperature is fine,let's do this for a short winter time solution only!in the front of your car with the hood up.look at the radiator,ok,in front of the radiator,place a peice of cardboard in front of radiator on the bumper side. think i'm crazy right? try this. cut just a small peice of cardboard about half the size of the radiator and insert it in FRONT BUMPER SIDE of the radiator, this will give you emegency heat,it will have to come out when the temperature outside warms up because it will make your car overheat.for sure.but in cold weather,it's a sure thing to bring the heat up inside the car. you are restricting the air that flows through your radiator while the cars moving down the road,do not let car idle as it will heat up,as long as you're moving you will be safe,keep an eye on your temp. guage as you may have to make an adjustment to the size of the cardboard. yep i was a truck driver for many years and know so well how cold the road is. i kept my cardboard handy in the winter and never got cold. you do have an existing problem with your heat,and unless you deal with it soon,you'll need those cardboard boxes and duct tape for a minute.if you don't beleive me,try it.you'll be toasty in no time,just watch that temp guage and you'll be fine. thank you for choosing fixya.com and by the way,let me know how it works for you,i love to hear that i've assisted someone,somewhere.
Jan 22, 2011 | 2001 Ford Taurus
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Cooling fan cuts off
The fan relay is not functioning correctly or the new sensor is defective.
Jun 02, 2009 | 1995 Ford Mustang
I need help with my central heat and air unit, it has a heat pump. the model number is GQ3RA-036K. I am changing the theromstat out and the wires are connected to it. there are eight wire colors that are...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
May 07, 2009 | Heating & Cooling
Cooling fans
flush and clean your radiator.you can get radiator flush and cleaner at the parts store. if that doesn't work take it and have it cleaned . that's if your fan and thermostat is working properly, which they probably are unless i'm misunderstanding you.
Feb 11, 2009 | 1992 Buick LeSabre
Have a coleman 5640 heating/cooling unit and the motor won't run unless just a tiny amount of pressure added?? Any suggestions?
Yes, to change from heat to cool is done by reversing the power plug that is close to the housing. Matching the blue on the plug(as I recall) makes it cool. The red to blue makes it a heater. If it is currently heating, the unit works fine, it just needs the polarity reversed.
Good luck,
Glenn
May 04, 2008 | Heating & Cooling
Ruud Central System Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
