Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Ice maker isn't working - Maytag MFD2560HES Bottom Freezer French Door Refrigerator
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Mar 21, 2011
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
I have FBW600S omega fridge/freezer side by side. Ice maker still makes ice but when ice cube tray motor turns to empty cubes ice still stuck in tray
there's a heater on the ice maker,if the ice isn't coming out i'd have to say you have a bad ice maker
Nov 08, 2011 | Refrigerators
Kenmore 106.56666500 ice maker not working
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
This will help. Thanks. Helpmech.
Oct 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What's your problem?ice maker isn't working
Assuming the coils underneath the ice box are clean and the ice box freezer section is running under normal operating conditions so that the ice mold thermostat can close contacts @25F, their are 2 suspects. The ice maker itself and the ice maker's water supply valve. Most of these supply valves have 2 solenoids for ice maker and water through the door. If the water valve is ok then the ice maker is bad.
Sep 27, 2011 | Kenmore Side by Side Refrigerator
Hi just bought a Samsung RSG5PUBP fridge freezer it is all plumbed in and the water function works but the ice maker does not. So far it has been on for 24hours. Any ideas???
Most ice makers require you to lift the metal arm up, for it to activate! Not in a straight (horizontal) position! But level (vertical) with ice container. Like resting on top of container, but not touching.
If this isn't the case, than you really need to check the water line going to the ice maker in the back of the refrigerator...check all connections, and trace the water line all the way to sink. You may have a blockage somewhere, or possibly a faulty ice maker?
These are usually, the main troubleshooting tips for ice makers!
Kind Regards!
Sep 10, 2011 | Refrigerators
The ice maker isn't working any more. It was making a clicking noise and no ice would fall into tray, now there isn't even the noise.
its just cheaper to by an aftermarket ice maker and replace it as its cheaper than repairing the old unit
Jun 30, 2011 | Magic Chef CTF1826AR Top Freezer...
Water thru the door does not work
First, is your ice maker making ice normally? If it is then you have water. If it isn't then it might be time to replace the water filter! If the ice maker IS working then it has to be either the dual water valve solenoid or the switch.
Jun 16, 2011 | GE Refrigerators
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Whirlpool fridge ice maker not working. ice begins to form but isn;t dispensing. melted ice in case was stuck, little prongs are down
You need to replace the icemaker . Probably the mold heater is bad but it cant be changed .
Aug 26, 2009 | Refrigerators
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
119 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
