Machine off balance - Washing Machines
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 21, 2011
Electrolux w4180h unbalanced error
Modern electronic machines have out of balance protection to prevent the machine damaging itself with an out of balance load. You CAN NOT wash just one item - for example One jumper - or any out of balance load for this reason. Add more clothes - or balance the load
Sep 22, 2017 | Electrolux Washing Machines
How to operate a wheel balancer phoenix pwb 1530
Installation
Remove Wheel Balancer from shipping crate and pallet.
Place Wheel Balancer on flat and stable floor.
Install the Safety hood.
Install threaded rod to spin rod extruding from side of the machine
using the hex bolt.
If Wheel Balancer shakes or moves while spinning the wheel, it needs to be bolted to the ground to ensure proper function.
Electrical plug is preinstalled to fit North American 110 volt electrical socket.
Plug into proper electrical socket. Do not hard wire directly to your electrical source. There is no power surge protection on the machine. Please use a power surge protector to ensure your machine is not damaged.
Install the wheel balancer in a dry and safe environment. Exposure to moisture or extreme heat can damage the components inside the wheel balancer.
VISIT: http://www.nhproequip.com/PDFs/PWB-1530-Operators-Manual1.pdf
May 03, 2014 | Computers & Internet
Intermittent no spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Washing machine balance is off since we moved it.
There are tension springs attached to the tub. They are for the balancing upon spinning. Check and see if one came loose
May 12, 2010 | Maytag EPIC MFW9700S Front Load Washer
I hear water in the washing machine when move it and think maybe water is building up in the machine. What should I do?
What you are hearing is the liquid inside the balance ring at the top of the wash tub. You could set the machine in the center of your driveway and drain every drop of water from the hoses and pump, yet you would still hear the liquid in the balance ring when the machine (more specifically, the inner tub) is moved. It needs to be there to help balance out of balance wash loads.
Apr 10, 2010 | GE WJSR2070B Top Load Washer
Out of balance on spin cycle (machine is level)
The balancing straps that hold the drum in balance could be broken or the springs could be wore out.
Jan 11, 2010 | Washing Machines
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Sep 09, 2008 | Bosch Washing Machines
To whom it may concern, I have Simpson riviera 740 washing machine and it keeps unbalancing itself and it's becoming more frequent, what may be causing this and what can i do to fix th problem? Regards,...
Washing machine must be balanced acting on the feet and putting machine at balance:
See here how to balance a washing machine.
If this does not fix it check the following points from Acmehowto:
Aug 29, 2008 | Washing Machines
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Apr 15, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
