Question about Kenmore 24032\24036 Top Load Washer
My washing machine continue flowing water does not stop, what is remedy? please help
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Posted on Mar 21, 2011
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
I bought a top loader last year and for the first time is about to use it. the instructions are in French but with pictures so I can work it. however the water continues to run overflowing onto the floor....
sounds like bad water pressure switch or a bad water inlet valve, does it have water in tub when not in use? does it stop filling when u unplug it? sometimes the tube connceted to the water pressure switch ( located in the panel) may come loose in the moving of machine and will cause an over flow of water
Mar 03, 2015 | Washing Machines
Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Dec 17, 2010 | Washing Machines
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
