Question about Kenmore Washing Machines
Kenmore 80 series mod 24824822200 need instructions on draining manually. Just buzzes when motor is engaged.
    Brigadier General:
  • 6,277 Answers
(try all of this!)
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 21, 2011
My top loading Kenmore Series 80 top loading washing will not run. When I noticed the motor would not engage agitation, I checked the circuit breaker and found that it had switched off. Turned breaker...
I would use a voltmeter and test the power to the motor. If there is power, then motor is faulty. If motor spins but not agitator then ****** could be bad. If no power to the motor, then a fuse or main circuit capacitor may be bad but testing with a manual and multi-tester meter will be needed to test for the failed componenent
Jun 09, 2012 | Kenmore series 80 Washer Motor 3363737-
Kenmore 80 Series 23812100 won't spin or drain. I can hear the motor make a buzz, but it never initiates. What is causing this? Thanks. :)
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | Kenmore 23812 Top Load Washer
80 Series Kenmore Washer, No draining or spin cycle
It does sound like a controller problem. Go to: SearsPartsDirect.com for parts diagrams and part numbers.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
I need instructions on replaceing the motor coupler on kenmore washer series 80 mod 110-24822200 typ 111
Check the video at the following link and see if it is of assitance to you in changing the coupler. Sure hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Oct 04, 2009 | Washing Machines
Kenmore 80 series mod 110225842400 stopped working during cycle. Tub won't drain and will not agitate.
Hi, When the washer is in spin or wash cyles, do you here any motor noises? It sounds like the lid switch might be bad. Sometimes you can actually see if the lid switch is broke or not. Please let me know if The lid switch appears to be the problem or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 20172 Top Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Washing Machines Logo
20 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
