Question about Sony STR-DE425 Receiver
I have a sony str-de 405 recevier . how do i connect a subwoofer to it .....
    Brigadier General:
  • 8,546 Answers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE405-Receivers-manual/id/387bh944/t/2/
and refer to the manual that should have come with your unnamed subwoofer.
Posted on Mar 21, 2011
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Helo ! I need to know why the subwoofer is silent when I connect it to my receiver-STR DE 475 . Plus , the sorround does not work . When I push the bottons , I either get the centre with the front...
Have you looked at the manual? There are procedures for adding a sub (which is NOT necessarily assumed to be there) and assigning bass to it.
http://www.retrevo.com/support/Sony-STR-DE475-Receivers-manual/id/387bh949/t/2/
Then there's the unidentified sub's manual and requirements to consider.
Sep 01, 2011 | Sony STR-DE475 Receiver
Can I connect a passive subwoofer Sony SS-W581T to a SONY receiver STR-DH510 ? Thank you
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Apr 17, 2011 | Sony STR-DH510 5.1 Channels Receiver
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
No sound output sony str
Unplug and replug connections in firmly and try again. Nothing? Check that the subwoofer is getting power. The sub sometimes has a built in fuse. Check that the fuse is not blown.
Feb 12, 2010 | Sony STR-DH500 A/V Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
No voice audio
Have you selected coax mode with the input button?. If so you may need to play around with the setup buttons. Can't give anymore advice as I've lost my manual. Good luck
Dec 26, 2008 | Sony STR-DE585 Receiver
Sony STR-DE425 Receiver Logo
408 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
