Question about Dryers
There is no heat and the vent is not plug and can't find the heating element
  • Terri White Mar 21, 2011
    Brand and model # would be helpful for this question.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 21, 2011
Ge ds4500eboww
Pull off exhaust vent. Clean. Remove back cover. Clean all airways free of lint and debris. Is this electric or gas dryer? If electric, plug back in and run dryer. Is the heating element glow red? Yes, check and make sure that air is now flowing freely out the back of the exhaust vent. No, replace heating element.
Jan 11, 2014 | Dryers
Dryer will not heat up
A faulty heating element, bad wiring, or plugged exhaust vent. Also in the venting is a flap that closes when dryer heats and opens when it cools, the flap can get stuck or the actuator that moves it can become faulty
Apr 30, 2010 | Amana ALE230RAW Electric Dryer
Dryer only heats minimumly and is not drying clothes. Do I need a heating element?
The first thing you can try is pulling the dryer out and disconnecting the vent hose. Then run a normal load of close through the dryer to see if it drys the cloths quicker. If it does then the element is okay your vent is just plugged somewhere. You can check the temperature of the exhaust air with a meat thermometer which should be 120 to 160 degrees farenheit. If it is not then you may have a bad heating element.
Jan 04, 2010 | Dryers
I switched my Kithen Aid Electric dryer [KEYE664W] from mediun to high heat AND THE HEAT STOPPED! Now all temps have know heat. Blower works.
You may have had a short circuit between the heat selector switch and the element/thermostat!! Have a technician test the heat switch, and the element and thermostat.
Dec 14, 2009 | Amana NDE2330AY Electric Dryer
Dryer does not heat up. tumbler does work.
Gas or electric dryer? If it is electric the heating element may be bad or a thermal limit switch near the heating element may be defective. Is the outside vent plugged?
Sep 24, 2009 | Kenmore Dryers
My lint screen has no lint on it after drying a load. it also takes more than 1 cycle to dry. I have checked venting and it is clear. Heating element seems to be working, gets hot and goes off, comes back...
generically: Danger Will Rogers Danger...Better try to get inside the cabinet and check the venting....
..possibilities:
Vent pathway plugged (hence no lint) and lint backing up inside cutting flow and thermal sensor shutting down heating element.
..Vent hose in hole of cabinet but not connected to duct inside cabinet and lint is just filling cabinet. (common reason for premature heating element failure--3 times for my aunt fixed by tech--before I saw the vent hose connected only to the cabinet)
...both of the above is a hazard and can burn out the heating element.
..might possiblly be able to back blow through the vent hole and/or lint trap with a shopvac/vacuum cleaner (try **** and blow); but if works still need to verify that air pathways are clear and vent hose connected properly inside--should be fairly obvious inside.
...hope helps
Aug 09, 2009 | Roper RES7648E Dryer
Whirlpool dryer....heats
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Clothes Arent Drying
Try running a load without the venting connected. Your venting may be plugged. If that isn't it, check the heat element. Inspect it for a break. It may heat partially if it is broken and touching the housing. Hope this helps!
Feb 08, 2009 | Kenmore Dryers
Dryer operates but will not heat up.
Check to see if your venting is plugged with lint or anything else. I had placed a new outside vent cover with a screen on it to keep the critters out of the vent pipe and that screen clogged up with lint. The dryer went thru all of its operations but the heat shut off right away because of this plugged vent.
Dec 04, 2008 | Dryers
Dryers Logo
Top Dryers Experts
