Question about Jaguar MCE6605 Air Conditioner
The cleaning fluid from the dirt devil ce6605 will no release from the unit to the carpet
2 Suggested Answers
SOURCE: Jaguar Dirt Devil Delux Carpet
have you found out what the answer is yet?
Posted on Mar 21, 2011
Sprayer on carpet cleaner won't release water
Hello! If your Dirt Devil carpet cleaner is not dispensing cleaning solution, there may be air buildup in the line. Try priming the trigger.
1. Plug the cleaner in.
2. Recline the handle and pump the trigger about 30 times
3. Power the clean on.
4. Hold the trigger in for abut 30 seconds.
The cleaner should start to dispense the cleaner. Hope this helps!
Aug 27, 2014 | Dirt Devil Carpet & Rug Shampoo 1700912044
Can you clean carpet with dirt devil floor keeper
Refer to http://www.dirtdevil.com/products/details.aspx?id=MCE5500 for the manual.
From the looks of the manual it's just for flat floor surfaces (vinyl, lino, tiles, etc).
May 25, 2010 | Dirt Devil CE5500 Floor Keeper Upright...
A few years ago we bought a Dirt Devil Carpet CPR and several bottles of the cleaning solution that goes into the sprayer. We are looking now to find additional bottles of that solution. Where can we find...
When I looked for your product at Dirt Devil it says " out of stock . I found what I think is what your looking for on EBay. NOTE: not my product not my store ! Click on the link below to see if this is what your looking for.
http://cgi.ebay.com/Dirt-Devil-Carpet-and-Rug-Shampoo-Cleaner-64-oz-Bottle_W0QQitemZ370317469793QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5638a42861
Best of Luck,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Jan 10, 2010 | Dirt Devil Carpet CPR Vacuum
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
How to clean inside dirt devil scrubber
Check out http://www.vax.co.uk/support/vacuum-cleaner-user-guides?downloadID=41
This is the UK version of the same machine - it will show you how to clean it inside. In terms of carpet solution, you can really use anything - such as 1001. You don't have to buy the expensive ones!
Apr 11, 2009 | Dirt Devil SE2800 Spot Scrubber Handheld...
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Heating & Cooling Logo
63 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
