Question about Acer Computers & Internet
What is correct hard drive to replace original in an Acer 5051 aspire laptop?
  • 76 Answers
To my knowledge the Acer Aspire 5051 takes a SATA HDD, any 2.5" SATA HDD will do, but you will need to install an operating system once you get it. Here is a link to all the new SATA HDDs on ebay:
http://computers.shop.ebay.co.uk/Laptop-Accessories-/31530/i.html?rt=nc&LH_ItemCondition=1000&_nkw=laptop%20hdd%20sata&_dmpt=UK_Computing_HardDrives_RL&_fln=1&_ssov=1&_trksid=p3286.c0.m282
Hope this helps you
Posted on Mar 21, 2011
Testimonial: "Many thanks!"
  • 43 Answers
Any SATA 2.5 hard disk will work, but you want it to be 7200 rpm. Right now Solid State Drives are really cheap - you can get an intel 40GB or 80GB which would REALLY speed up that laptop.
  • 76 Answers
I believe it is a 60-GB SATA 5400 rpm hard disk drive .
Testimonial: "many thanks, i had no idea. Had laptop since new, but now its basically had enough. Thought i'd sort it and use as a second!"
How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Jan 24, 2010 | Acer Aspire 5630 Notebook
I want to know what type of hard drive I can use in an Aspire 3680.
The specs show an 80 GB hard drive. Probably ATA (you can tell by looking at the end of the drive--if it has a bunch of pins on it, it's ATA. If there are only two connectors, it's a SATA.
You can probably go to 150 GB or so. Don't go too large or you'll be bound to have problems. Mostly there are 120 GB and larger drives out there now. They don't make 80 GB any more.
Dec 18, 2009 | Computers & Internet
A Hard Drive Space Upgrade Limit?
No, there's no harddrive size limitation.
Apr 19, 2009 | Acer Aspire 5050-3242 Notebook
Lost Hard drive
The hard drive has gone bad and needs to be replaced.
And please remember to rate this solution as fixya. Thanks! :c)
Jan 25, 2009 | Acer Aspire 3680 Laptop
I have acer aspire laptop purchased from dabs feb 2007 hard drive crashed 2 weeks out of warranty, i have put in new hard drive, how much would it cost to puirchase the discs for operating system serial...
If your Aspire laptop has a Microsoft sticker at the bottom with the Product Key, it is not necessary for you to re-purchase CD installer of the Operating System. You could try borrowing from friends their XP Pro CD installers or even an OEM and simply use that. When asked for the CD key, use what is printed in the aforementioned sticker.
As long as the motherboard/entire machine is not replaced, then this would be an acceptable alternative. Should you still wish to purchase an Windows XP Pro SP2 installer CD, it would roughly cost USD 60.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Computers & Internet
Keyboard is not getting recognized on acer 5051
Dear npjay,
Please connect a usb keyboard at one of the laptop's port. This will most likely (and hopefully) trigger windows installation to use this one.
Regards
Please dont forget to rate this solution if you found it useful.
Apr 02, 2008 | Acer Aspire 5050-3242 Notebook
Removal of cd/dvd tray from acer aspire 5051
hi
turn your laptop back there you can notice a closers like ram, hdd and cpu
remove the ram closer there you can see end of the cd drive, Before that screws which is indicate with the cd symbol,(see near the drive tray carefully)
then gently push the cd drive catefully from the back side , under the ram drive
Mar 17, 2008 | Compaq Presario 700 470024-192 Notebook
Look on the bottom of your laptop on the side where your cd drive is. There will be a screw that is centered with the cd drive, about 6 inches in. It should have a "lock" symbol next to it. If you take that screw out, the cd drive will be allowed to slide out then. You might need a screw driver to help pry it out though.
Jan 12, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
344 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
