Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hi my hoover f7425-900 is not releasing water from the clean water tank but the detergent is being released can you help me? thanks
  • 240 Answers
The most common reason for this problem is that the solenoid operated valve on the rinse cycle has failed, and is not opening. The solenoid assembly will probably require replacement.
Posted on Mar 21, 2011
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
Water solution does not come out--is something plugged
It could also be due to the brush assembly channels being clogged. Remove the brush assembly and clean channels by running under warm tap water.
To clean the brush assembly/nozzle, turn cleaner off and disconnect from electrical outlet. Slide the two nozzle release latches outward. Remove the nozzle by pulling straight out. Rinse nozzle under running water. Remove debris from squeegee and wipe with a damp cloth. Using finger grips on the brush assembly, pull straight out. The brush assembly can be washed with a mild detergent and rinsed. Do not use pine or solvent-based detergents.
To replace nozzle, make sure latches are out. Align middle section of nozzle with opening on cleaner. While holding nozzle in place, slide latches inward to lock in place.
Make sure your solution tank is full and securely locked in position.
Lastly, if this fails, you can contact the Hoover Service Center by calling 1-800-944-9200 for an automated referral of authorized service outlet locations (U.S. only).
Jul 29, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Suddenly the automatic deterent mixing system in my hoover steamvac widepath (model F7443-940) stopped from working. It does not dispense detergent anymore. What could the problem be?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766252
Generic problem for all Vacuums
Suddenly the automatic detergent mixing
Posted by btaha on Jul 10, 2008
Suddenly the automatic detergent mixing system in my Hoover SteamVac WidePath (model F7443-940) stopped from working. It does not dispense detergent anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be the trigger assm could be broken and is not releasing the solution and or water, or the valve under the water solution tank is not releasing the solution. Please check with your owners manual in the trouble shooting manual or if you do not have a manual, call the Hoover factory cust serv and give them the brand name and model # so that they can send you a new owner’s manual. Your local vacuum cleaner dealer should be able to do a diagnosis of the problem and can give you and est of the repair. Or if the vacuum is less than one year it should be covered under the Hoover factory warranty. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
F7425-900 hoover steam vac
There is a valve at the bottom of the tank, push it in and see if it goes in and out ok. The tank sits on the reservior asm., a rod in the handle pushes it when you squeeze the trigger. You may have a problem with the rod not releasing or a bad reservior asm.
Apr 26, 2008 | Hoover F7431-900 SteamVac Vacuum
buy a new solution tank. the problem might be that your not rinsing the tank with clear water after use and the soap hardens on the release button of the tank.
Feb 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Detergent won't dispense
Check the valve at the bottom of the tank, does it push up then come back by itself (part #43513014)? If it is ok, then there may be a problem with the plate that the tank sits on or the plunger inside the handle isn't pushing to release the detergent.
Feb 08, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
128 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
