Question about GE Washing Machines
Model WWA81726 off balance - GE Washing Machines
  • Terri White Mar 21, 2011
    Do you mean that the feet need to be adjusted to keep it level or that it is off balance with clothing when spinning?
    Brigadier General:
  • 6,277 Answers
(this is a repeat, of course!)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 21, 2011
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
I have a Phillips RC604 stero in my hyundia 99 model and the balace has shifted to the rear while cleaning the car iand i cant figure out how to get to balance setting
press the mode button it puts you in touch with the operations loke balance front rear , left right, bass, treble etc and readjust the balance setting
Apr 22, 2017 | Cars & Trucks
What tools do you need to change a harmonic balancer?
Depending on year/make/model. An air gun or strong electric gun works best to remove the bolt securing the balancer to the crankshaft. Some but not all models will need a puller to remove the balancer. Without stating model etc,I can offer no more advice
Jul 26, 2015 | Cars & Trucks
H4ce180a25a compressors with oil balance
based on that model number any 15 ton unit would be ok
Jun 05, 2013 | Air Tools & Compressors
Balance is giving me a Err 8.2 message when it is turned on. Unit is an analytical plus model AP250D
The error 8.2 is pretty general. Most likely it is caused by damage to the load cell. There are some things you can try before you decide to get the balance repaired.
1. Turn the balance off and unplug it. Count to 20 and plug it back in anf turn it on.
If that does not work.
2. Put a 100g weight on the platform (the weight does not have to be exact).
3. Plug the balance in and wait for the count down. If the count down starts at 99 you can stop this procedure will not work. If the count down starts at 255 continue.
4.The balance will read error 8.2 again at the end of the count down.
5. Unplug the balance.
6. Remove the weight.
7. Plug the balance in and wait for the count down. The balance should count down and turn off.
8. Turn the balance on and it should work normally.
If this does not work the balance needs to be repaired.
Sep 13, 2010 | Ohaus Measuring Tools & Sensors
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
I have misplaced the manual for my receiver. I need to know how to balance my speakers. I can only do it at the receiver itself.
You haven't told me what make nor model of receiver you have. That would help A LOT. Anyway, most systems have a power amplifier and a pre-amplifier. Receivers have both, but they are in the same box and to the average user are in-distinguishable. The amplifier it's self (for all practical purposes) has no "balance" control. Any gain adjustments including balance, are done at the pre-amplifier level, and in the case of a receiver, that's probably the only place you will have to do any balancing. Beyond that, you may have an L-PAD or some kind of volume adjustment at the back of your speaker cabinets. If that is the case, you could do some additional balancing there, but if you're looking for symetry in your sound, there should be no need for balance adjustment. If you find that one of the channels is noticably quieter than the other, and yet your balance adjustment is set to the middle, then we need to investigate to find out why, but I don't think that is the problem that you are describing. If you already know how to set the balance at the receiver, then you probably know just about all there is to know about setting the balance on that system. Again, I am not familiar with the system, as you have not given me the make nor model.
Oct 24, 2009 | Audio Players & Recorders
Balance model 557S
if you can send me a picture of the old motherboard i can find you a motherboard that can fit that model case.
Jan 03, 2008 | Balance CN6555 Notebook
Balance CN1401 tv tuner software
Hmmm... interesting finds for this model. Apparently built buy ECS for Walmart distribution under the name of Balance.
There is no Balance website and no information from ECS. But from what I have gathered this evening, from searching online, it should be the same as the ECS line of laptops from the same time period.
Go here - http://www.ecs.com.tw/ECSWebSite/SearchResult.aspx?q=tuner&f=Downloads&MenuID=104&LanID=0
Scroll down to model 332 and try the TV driver listed on the bottom of the page. Most of these models from ECS share the same LifeView TV Tuner driver.
I couldn't find any relevant specific information for Balance CN1401. Other than it being an ECS built laptop for Walmart Balance branding. So theoretically, and ECS driver should work. If that one from the 332 doesnt work, then check some of the other models listed.
Is this going to be for Windows or a Linux based operating system?
Oct 30, 2007 | Balance CN1401 Notebook
Washing Machines Logo
19 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
