Question about JBL Venue SUB10 Subwoofer
I just bought a jbl sub150 surround sound. my question is does it need a recevier to work or do the little speakers plug into back of sub
    Brigadier General:
  • 8,546 Answers
Didn't it come with a manual?
Of course it needs external electronics to provide sound sources, controls, bass management AND amplification for the other speakers. It's just a sub.
Posted on Mar 21, 2011
How do I connect jbl psw1200 sub?
Well, it depends what you're connecting it to....
If it's a stereo receiver or Hi-Fi amp, then the speaker cables that would normally go direct to the front L & R speakers now connect to the sub's L&R speaker OUT sockets. Then you need two extra lengths of speaker cable. These go from the receiver's speaker outs to the sub's L&R speaker IN sockets.
Connecting to a surround receiver, just use the phono/RCA cable from the receiver's "Sub Pre Out" to the white phono/RCA labeled Low Level IN.
Aug 30, 2014 | JBL Audio Players & Recorders
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Nov 23, 2008 | Yamaha HTR-5850 Receiver
Friend gave me a jbl surround system to go with my 52" sony hd tv. It has four speakers. three sat 20 and one bass 20. going to a rca stva 3970 receiver. didn't have instructions to go with it.
You need two more speakers to get surround sound,ie> two front one center and two for surround,then you need a home cinema amp to run the speakers and decode the sound from your tv,sky,dvd etc,and the sub gives you your bass.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | JBL 5.1-Channel Home Theater Speaker...
Jbl subs
One time I had 2 MTX 10" subs that had a rubber surround. I was playing it a little hard and tore the surround pretty much all the way around. I bought some windshield urethane and glued it back together. I got rid of them a little while after that and surprisingly the guy who bought them tell me they still sound great. So the answer is yes and no. Depending on the surround you might be able to get away with it. Make sure that you use something that stays flexible even after setting. Also depending on where the tear is and how big it is, it might not even hurt the sub. I hope I could help.
-Andrew Hawkins
Apr 02, 2008 | Audio Players & Recorders
JBL Venue SUB10 Subwoofer Logo
246 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
