Question about Novelty "Ford Thunderbird" CD Alarm Clock Radio with Neon
1995 Ford Thunderbird radio and clock stopped working. I have replaced all fuses associated with both and pulled out stereo to see if had fuse behind the stereo since it was aftermarket and it does not. Can you help me please
What kind of fuse does the clock use on a 1962 ford thunderbird
It takes a 1amp 12v. buss fuse. (the short one). Buss fuses are small glass tubes with metal caps on the ends.
Jul 24, 2014 | Ford Amt 1962 Ford Thunderbird 125 Model...
1986 Thunderbird troubleshooting
there are 2 fuses boxes in cab and 1 in engine bay
we test the fuses, we dont change them out willy nilly.
even better, is to measure the voltage at at the radio.
the power pin is 12vdc, keyon
if not the fuse is blown or the wire is cut.
end story.
my guess is car wiring was hacked long ago with stereo upgrades
or other hacks, (alarms,etc)
old cars are like that, hacked.
May 10, 2014 | 1986 Ford Thunderbird
Clock and radio stop working
check fuse first let me know what yo have done so far
Apr 22, 2014 | 1992 Ford Thunderbird
Where is the fuse for the instrument panel on a 2002 Ford Thunderbird?
I'm not sure about the 2002 T-bird, but a 1992 T-bird has a fuse labeled MEM in the box behind the battery on the left side. It's a 5 amp fuse that's for the instrument cluster, the error module memory and the radio.
Mar 13, 2014 | 2002 Ford Thunderbird
Radio, CD player, Sync, clock stopped working on my 2008 Ford Explorer
Most likely a fuse. If your fuse box is labeled it will say radio under the fuse. If its not check your owners manual for location of fuse box and radio fuse.
Mar 04, 2013 | Cars & Trucks
96 ford thunderbird power windows
YOU NEED TO CHECK THE CUIRCUT BREAKER USUALLY LOCKATED IN THE FUSE BOX
Apr 11, 2012 | 1996 Ford Thunderbird LX
Where is the fuse box located, 1995 ford thunderbird
the fuse box is under dash on drivers side. by the e-brake. good-day !
Nov 19, 2011 | 1995 Ford Thunderbird
My radio and cd player or lighter doesnt work. but my clock does.....what is wrong!
Change out your ACC Relay. It is located on drivers side behind kick panel in fuse box. It is Black and rectangular shaped. Check for moisture. Many times water comes off driver door Chanel right into fuse box. Open driver door look for holes in front panel. ACC Relay is under 10 bucks at auto parts store.
Jul 04, 2009 | 2003 Ford Escape
CLock, radio, dome lights, speedometer, keyless entry dont work
Check fuse 8 (10 amp fuse) in the under dash fuse panel. Make sure you have voltage to it on both sides of the fuse.This fuse feeds all of the items you listed.
May 25, 2009 | 1995 Ford Mustang
Top Novelty Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Novelty Audio Player and Recorder Expert? Answer questions, earn points and help others
