Question about Dell 948 All-In-One InkJet Printer
It will not print. It passes the paper through without printing anything on it. The ink cartridges are new. It prints a test page. but it will not copy. The computer says its ready to print. The printer says its printing. The paper slides down and then slides out the front without printing anything on it.
  • 98 Answers
A test page prints with the proper ink/text showing up?Have you tried restarting the computer? Have you powered off the printer and turned it back on? You could try reinstalling the printer software and see if that helps.
Posted on Mar 21, 2011
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
My printer is printing blank pages What is wrong?
You may clean the cartridge by following the steps given below:
1. Remove the cartridge or cartridges from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridges back into the printer.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Apr 16, 2009 | Lexmark Z617 InkJet Photo Printer
Printer was left without ink cartridge installed for extended duration
nope..that's not really an issue with the drying out. it's more likely that the print cartridge MAY have the tape still installed. Try the steps again..and then do a test page.
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Canon PIXMA mini260 InkJet Photo Printer
PRINTER CARTRIDGE STALLED
Is there someting stuck in the printer like a pencil or a keychain, something small that would allow paper to pass but also trigger a sensor in the printer as the printer can detect that paper is being passed unevenly.
Question: does it just say that the ink cartridge is stalled or does the cartarige really stall?
Feb 20, 2008 | Computers & Internet
Printer "prints" but when it's done, no ink shows on the page.
When you filled your cartridges were they empty? If so there is a good possibility that the nozzles are gummed and dried up. If you are going to fill them yourself watch the indicator that comes up on the screen it will tell you when you are getting low. If you get a low indication fill it asap. This will keep your nozzles wet and free flowing. Waiting until its empty can cause them to gum up and altimately dry out. My solution is to go to the store buy brand new cartridges. Go through the the full set up that your manufacture recomends. This means using the install new ink cartridge utility that came with your printer. Print a test page and print a nozzle aligment page. Just remember never let your ink completely run out before filling. If you follow this you will never run into this problem again.
Sep 21, 2007 | Canon Pixma MP500 All-In-One InkJet...
Dell 948 All-In-One InkJet Printer Logo
167 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
