HP DeskJet F380 All-In-One Printer Logo
Posted on Mar 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a iPad 2 with the Airprint capability to print documents, web pages, photos, etc to my HP Deskjet F380 All-in-One. When I select to print something, the printer is found, but a username & password login bog appears. Hmmm, I don't know where to look for this username & password so I can proceed to use this feature. Any ideas on where to begin to snoop around for this solution? Thanks in Advance.
Anonymous
Level 2:
New Friend:
  • Expert 98 Answers
  • Posted on Mar 21, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
98
Questions
0
Helped
21701
Points
267
It could be that you need to enter the password for the network - the password that the router uses. Or, maybe it is a username and password for the iPad itself, so that it blocks others from getting ahold of your iPad and using functions like the Airprint and others that you wouldn't want them doing.
How to Print From iPad to HP Printer?
The easiest and quickest way to print from iPad to HP printer is through AirPrint. You can use the Apple AirPrint feature if you want to print your documents from the iPad to your printer. First of all, make sure your printer and iPad device is connected to the same Wi-Fi network. Then, open the document that you wish to print and tap on the share button. Next, tap on Print and set the Print options. At last, click on Print located in the top right corner to get the printing job done.
1helpful
2answers
How do I add my iPad to my printer?
Here is a solution to add the ipad to your printer.
Follow the below steps to add:
·You have checked the latest version of iOS on your iPad.
·You have to connect the iPad to the wireless network by using the network name and password.
·You have AirPrint enabled printer.
·Now days the Air Print is built into most of the popular printer models. To check if your wireless printer is supported, you can view the list of Air Print enabled printers on Apple's website.
·You have a printer is connected to the same network as your iOS device or Mac. Your iPad won't recognize your printer.
·After turning on your printer, wait a few moments before printing from iPad or iPhone. Some printers take a minute or two after powering up before joining your network.
·You have to setup printer on iPad correctly to open the printer's software on your computer and look for a check box saying "Enable AirPrint."
·You can only use AirPrint with iOS core programs, such as Safari, Mail, Pages, and Photos, you can be print items like emails, photos, documents and WebPages directly from your iPad.
·Click the action icon button located on the top bar of the program screen that looks like a rectangle with an arrow coming out.
· This button will open a menu options. Tap the 'Print' button from the choices that appear to load the 'Printer Options' screen.
·When you are printing from iPad for the first time, you need to hit select printer. Afterwards your iPad would scan for the local AirPrint printer.
·Select the numbers of copies you want to print and then tap the Print button to print the desired item.
    If you have still facing any issues to add my iPad to my printer call to this toll-free number +1-800-836-3987 or visit this website 123.hp.com/oj6830.
1helpful
How can I print to canon pixma8120 from iPad?
Apple have their own proprietary printing protocol called 'AirPrint'. Only a few printers support it at present - HP is one of those that do and you can see if your model is on the list at the Apple web site
Apple - iPad - Print right from your iPad with AirPrint.
Canon also has an iPad app that works.
Search for Canon iEPP Easy Photo Print in the App store.
Otherwise you can use a program called FingerPrint - free trial available & $10 only to register.
Thanks Mark
Print wireless from iPad to Cannon PIXMA MG3250
a printer should be airprint enabled ideally, this will let you print from ipad etc, there is a list on the apple site: http://support.apple.com/kb/ht4356
or you could try various apps, one popular one is print n share
hope this healps :)))
Lost disk for HP Deskjet, and I need to install the software. Help!
Access the manufacturer's web-site: http://support.hp.com
and enter the model-number, and do the search.
Select your Operating System (XP? 7?)
Select the device-driver.
Download it.
Install it.
Print a test-page.
1helpful
How can i use my hp laserjet p1120w with my iPad by airprint
AirPrint lets you print wirelessly to AirPrint-capable printers. Make sure you have an AirPrint-capable printer.
AirPrint-capable printers don't require printer software; they just need to be connected to the same Wi-Fi network as your iPad.
If you're not sure whether your printer is AirPrint-capable, refer to its documentation or contact their support.
Here are the steps.
1. Tap (the back arrow) or (the forward arrow) (depending on the app you're using), then tap Print.
2. Tap Select Printer to select a printer.
3. Set printer options, such as number of copies and double-sided output (if the printer supports it). Some apps also let you set a range of pages to print.
4. Tap Print.
1helpful
HP DESKJET F380 ALL IN ONE PRINTING IN RED
Hi Jasmine
I am attaching 2 documents, please try the steps in the document, i think either the tri color cartridge is out of ink or it might be an issue with the tri color cartridge
try this document first : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423255&cc=us&lc=en&dlc=en&product=3390947
If No go then try this document : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429694&cc=us&lc=en&dlc=en&product=3390947
Please respond back so that I can help you.
Regards
Santhosh
Email prints in garbled code
try downloading HP Smart web printing from Hp.com web site, that should fix your email problems, reply back if the issue is not resolved.
Printer hp deskjet 3325
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:HP Deskjet 3325 printer
A web page will open, follow instructions, select operative system etc., browse several pages, and click on download .
Chose to download the file in my documents when asked.
Afterdownloading, find thefile,double click on the file, if you getin troubles,then follow the instructions below to reset and reinstall:
  • Unplug USB.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some device does not work on Vista
k24674
Grand Canyon Tech
Grand Canyon Tech
