Question about JVC Televison & Video
My screen is green and does not show a picture or sound! You cannot change the channel or access the menu! Is it the picture tube or lamp?
  • 98 Answers
Can you see menus if you press the menu button? You could be set to the wrong input that doesn't have a signal coming in. I have one TV that shows a blank blue screen when I'm on an input that has no signal. If there is not a signal on the input being used you will also not have sound.
Posted on Mar 21, 2011
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Jul 10, 2009 | JVC AV-36150 36" TV
There is a green tint to my screen. Seems to be more evident in dark shows and on shadows.
Pull the front speaker grille off and remove the access panel. In the customer menu turn the color off so you have a black and white picture. get a flashlight and adjust the screen controls for the red, green and blue tubes until you get a nice black and white picture. then turn the color back up.
May 26, 2009 | Hitachi 51F59 51" HDTV Projection...
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
No picture
check all resistors right in crt board & resolder picture tube connection. good luck!
Dec 04, 2007 | Sylvania SRT2232S 32" TV
Green Screen
Sounds like the green tube is shorted.
Oct 06, 2007 | Hitachi 50VS810 50" Rear Projection HDTV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Screen not showing picture
Check and make sure you are on tv not video. Unplug and replug all the game systems or other things you might have plugged in your tv. And if those don't work make sure you are not on input channels (input1, input 2, and do on). If still you are having problems go to the tv menu and and make sure you are on antenna if you have a antenna or cable or satilite if you are on one of those. I hope this helps!
Apr 11, 2006 | Thomson AQUA14 TV
Televison & Video Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
