Question about Lands Phones
Radio Shack 5.8Ghz Digital Cordless Phone (very new!) After power outage, I cannot get the base unit to recognize the handset. An error message "E 4" is showing on the base unit display. Cannot find error listing in manual. Thanks.
SOURCE: Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Posted on Sep 17, 2007
My battery is a Ni-Cd. I bought it new on eBay (TL26554 battery number). I allowed the new battery to charge for a long time and then tried to see if it would work. But no go....the handset gave me the same error message. Good Luck to you too! Mmmmmm
Posted on Sep 18, 2007
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Posted on Nov 19, 2007
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
phones say do not disturb and will not ring
Posted on Feb 28, 2008
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Posted on Feb 29, 2008
Power outage need to reset - blinks "CL"
remove the power adapter and remove the battery from the handset. Now replace the battery and power the base unit , place the handset on the base and select intercom or search remote.
The base unit must automatically set the frequency to mesh with the handset and handshake to connect.
Sep 19, 2011 | GE 25932 Cordless Phone
Radio shack 43-113 cordless phone
Re: "compatible extension hand set"
Have you tried Uniden DXI-986-2 900 MHz Cordless Phone with Dual Handsets and Extra Charging Cradle. You would have to disable the base of the main unit of the Uniden and simply use it as a cradle/charger. Additionally, it may be to your advantage to bring along your Radio Shack Hand set when trying/buying the Uniden to see it they will pair up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 22, 2008 | Radio Shack 433575 Cordless Phone
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
E4 error message
I have the same problem. Want to buy a new one, but would like to know if this can be fixed.
Apr 04, 2009 | Uniden TRU9485 Cordless Phone
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
Power outage messed up my phone
I am sure there is one to download but did not found anything with google... If search engines are of no help, just ask some deep web specialists, e.g. http://manualfox.com - if they don´t find it, it does not exist in the Internet.
Dec 08, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
Out of Range foe 5.8GHz Digital Radio Shack Handset
Hello rrno,
First try simply swapping batteries with
units that are still behaving...
and/or moving handsets around...
My experience has been the trouble travels
with the BATTERY...
Try purchasing a couple of new batteries.
My second suggestion... EDIT OUT your
email address... Skillful Scammers can hustle
you pretty good with an ID and a single point
in interest...
In the future... be a little more paranoid...!!
SERIOUSLY.
Carnac the Magnificent
Jul 01, 2017 | Uniden 5.8GHz Cordless Phone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Lands Phones Logo
85 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
