Question about Precor 9.31 Treadmill
I am getting a reading on the screen of "er 05" i
  • Precor Master
  • 918 Answers
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Posted on Aug 07, 2014
ER 05 displayed on precor 9.31?
Corrective Action
Nov 23, 2013 | Precor Exercise & Fitness
Er 1 error
Dear Sir:
adjust the speed sensor, see the diagram attached, clean, and tight the connector very well.
2) Test the input voltage motor, if there are the motor need repair or replace.
3) Test the output voltage from the main motor board for the input of motor, if there are NOT, the board is faulty.
4) After fix it, run the software calibration, for diagnose, and troubleshooting.
sincerely. God bless you
Apr 24, 2012 | Avanti Exercise & Fitness
ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Nov 16, 2011 | Kettler TX3 Folding Treadmill
Reebok 8700es treadmill w/ Universal iPod dock & Ifit Fitness Journal. Display screen is unreadable. Light is on but unable to read the numbers on the screen Treadmill features: Custom workouts,...
If the display is unreadable, the Display resolution is faulty
Time to replace since thee are LCD, this fail.
Call to the supply treadmill manufacturer. or
Treadmill Treadmills Best Treadmill Treadmill Doctor
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 08, 2017 | Reebok 8700 ES Treadmill - Silver Service...
The screen reads "Unit immobalized
Here is the manual for your unit. See the section on Managers Configuration specifically custom message on page 37.
http://jp.commercial.lifefitness.com/resources/content/4/9/7/3/documents/95Te%20Console%20User%20Manual.pdf
May 16, 2011 | Life Fitness 95Te Treadmill
The screen reads "unit immobilized
To Get to the manager and check for disabled items.
To enter the Systems Options Menu:
1. Press SELECT WORKOUT.
2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times
go to configuration
Configuration
Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected.
Manager Vivo/Network
Manufacturer , Create Your Own
Media Center , Clock
Custom Workouts
Touch Screen Configuration
Export / Import Settings
The console manual will show you all the default values .
https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
Feb 01, 2011 | Life Fitness 95Te Treadmill
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Precor 9.31 Treadmill Logo
134 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
