Question about Apple iPod classic MP3 Player
The play/pause button on my 80GB Ipod classic has stopped working. as far as i am aware it hasnt been droped or had any rough handleing. any ideas?
    Guru:
  • Apple Expert
  • 173 Answers
I have seen this.
One thing you can try is getting a can of 'air' see, the device gets 'buildup' underneath the click wheel causing it to not respond, and unless you know how to disassemble and clean, this is your alternate fix.
So... with the canned air, you have to be careful as when you spray it into device it will freeze things temporarily if you spray to much at a time, you must use quick direct sprays into and around the wheel, so quick spray, less than a second, wait like 40-50 seconds and doit again, working around the wheel.
hope it works!
Posted on Mar 21, 2011
IPod classic stopped shuffling this weekend. I've had it for several months and it's worked just fine, but all of the sudden it stopped shuffling songs within playlists that were set to shuffle. ...
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
Jul 20, 2011 | Apple iPod touch
80g ipod classic won't unlock or charge,and itunes won't
My 80GB Ipod classic recently froze. I took it to Apple store and the guy press the Menu and Center Button. Hold them until the APPLE logo appears twice. Then release the button.
Voila, my Ipod work again, no missing data
Jul 22, 2009 | Apple iPod classic MP3 Player
My iPod 160 GB Classic is stuck with just Apple logo on screen. Initially, my MacBook recognised my iPod but now it won't even recognise it. It won't restore it and message suggested I need to use updated...
Try forcing the iPod into disc mode to restore.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not make the iPod connect to your computer, I would suggest checking out www.rapidrepair.com for further ideas and options to your issue.
Jun 22, 2009 | Apple iPod classic MP3 Player
80gb Classic backlight on, no menu displayed
you LCD is Broken...Look for an iPod Repair in your area and have the LCD replaced.
it's a classic symptom of a damaged LCD..I see it all the time.
Apr 12, 2009 | Apple iPod classic MP3 Player
My ipod won't update or sync and some of the song are on the ipod but wont play some of the time what do i do?
my ipod wont let me copy song ive tries most things. it will not sync as it keeps pausing and i tunes keeps freezing. can anyone help.
thanks emma
Dec 19, 2008 | Apple iPod classic MP3 Player
Hi my ipod classic 80gb has stopped playing songs but everything else is ok
Try restoring it. Plug your iPod in and open iTunes, select your iPod in the list to the left in iTunes. Now right below the big picture of your iPod model there is a button that says "Restore," click it. Restoring usually take a few minutes.
Hope this helps!
Dec 14, 2008 | iRiver E10 Digital Media Player
Dont know how to off my ipod classic 80gb......
To turn your your ipod off, hold the pause button (button on bottom of scroll circle) for three seconds.
Oct 31, 2008 | Apple iPod classic MP3 Player
Ipod classic 80gb won't open and charge
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Oct 15, 2008 | Apple iPod classic MP3 Player
My ipod
Press and hold the center button while pressing down on the menu button until the Apple logo appears. That will reboot the Ipod. That should stop the lockup.
Aug 26, 2008 | Apple iPod MA446LL/A MP3 Player
My iPod keeps pausing!!
I got this fix from someone on one of these forums so I can't take the credit. It seems to sort the problem out though. Basically the ipod firmware auto pauses when you take the headphones out. Sometime the jack is so sensitive (especially if you buy new phones), that it thinks that you have removed them when you haven't. There is no way of turning this function off (that I know of). However, if you install Rockbox instead (a different operating system that has loads more functionality) then you can switch this function off, resolving the problem.
The only drawback is that you have to work with Rockbox. I only downloaded it last night but it looks pretty neat, way better than the default ipod one.
To switch it off you go to
Settings > Playback Settings > Pause on Headphone unplug > then there are 3 options to play with.
It's worked for me and stopped the infuriating pausing of tracks sometimes a dozen times per track. Relief!
May 19, 2008 | Apple iPod MP3 Player
Apple iPod classic MP3 Player Logo
692 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
