Question about Yamaha HTR-6060
Can't get my sub woofer to come on... Is their a section in the menu to turn it on and off.... it could be in the off position.. Thanks
    Sniper:
  • 54 Answers
Yes, for sure. system has switch about subwoofer on or off, download an user manual to figure out how to set up.
Posted on Mar 21, 2011
  • 643 Answers
Yes. its within the speaker setup screen. you need to tell it that your using a sub.
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
Nov 01, 2010 | Audio Players & Recorders
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
Yamaha HTR-6060 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
